Please help? Spotify, Nexus 7, but what HiFi?
21 replies [Last post]
s3rdy
s3rdy's picture
Tonestar1
Tonestar1's picture
RE: Please help? Spotify, Nexus 7, but what HiFi?
Hi S3rdy,
Your original post is just blank. Try posting your question as a reply to this. Hopefully someone will be able to advise.
T
s3rdy
s3rdy's picture
Thanks T - computer 9me problems
I have a Nexus and want to get a  sub £500 HiFi/player to play spotify, music files and CDs. Maybe also play my TV through the same system. I am using Wharfedale Diamond 9.1 speakers.  Cany anyone help? Not knowledgable on HiFi or latest tech so go easy please!
Tonestar1
Tonestar1's picture
No worries, I think it's the forum itself as opposed to your computing skills. Lots of the forum users seem to be having the same problem.
What do you use to power the Wharfedale speakers at the moment?
Also do you want to connect the Nexus to the device directly to play music or are you looking to stream the music via wi-fi?
s3rdy
s3rdy's picture
Thanks for you reply.
I was given the Wharfedale speakers and not using currently. I assumed they would be powered by the unit  I purchased. I dropped into Superfi yesterday and looked at the denon DM39, but I understand it is only compatible with the 'fruit based' technology
I am happy to either connect the Nexux direct or by other means - just whatever can help me realise the potential of spotify etc...
Tonestar1
Tonestar1's picture
You could connect the Nexus directly to the DM39 via a headphone to phono cable.
You could even stream from the Nexus 7 via bluetooth to a logitech wireless speaker adaptor (link below, £35) which would connect directly to the back of the Denon.
http://www.amazon.co.uk/dp/B0054QK514/?tag=nxtab-21
You could also use something like Sonos to allow you to stream wirelessly but you need an additional app to stream direct from the nexus 7.The Sonos product will also allow you to use the nexus 7 to play music from your laptop through the same unit.To meet all of your requirements you would need to buy an additional CD player.
With the Sonos system you would have the additional flexibility to add an additional unit at a later date to allow you to listen to music in another room.
Both of these options should cost less than your £500 budget.
As there are so many different options I would suggest another trip to a specialist dealer to find something that meets all of your needs.
Sorry I can't be of more help but the options are almost endless. Perhaps some other forum users will have other suggestions.
Tonestar1
Tonestar1's picture
bigboss
bigboss's picture
There are rumours of next Sonos update allowing you to stream music directly from your Android device.
__________________
s3rdy
s3rdy's picture
Thanks for that it was helpful because i liked the DM39 (due to price and ratings etc). Will the options you suggest give a good level of sound quality? Apologise if novice questions but I am.. well.. a novice!
John Duncan
John Duncan's picture
Online
Twonky Mobile claims to allow you to transmit from Nexus to AirPlay device. Let me have a go...
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
John Duncan
Online
__________________
bigboss
bigboss's picture
You could stream music from your Nexus 7 via bluetooth. puzzled
__________________
Tonestar1
Tonestar1's picture
I am sure both of the options I suggested will give you a half decent sound but the best way to find out is to get your local hifi shop to demo them for you. Then there won't be any nasty surprises when you get the kit home. If I were in your position I would be tempted to go with the Sonos As it allows a degree of expandibility as well as the ability to stream music from your laptop too. But that's me... Only you can decide what's right for your needs.
Good luck and welcome to the forums.
s3rdy
s3rdy's picture
#bigboss no bluetooth on Denon DM39 - where you thinking of something else?
Tonestar1
Tonestar1's picture
That was my first suggestion, logitech Bluetooth receiver. I've been reading about lots of problems with 4.2 and Bluetooth though.
What would you recommend BB? I'm  sure the OP could do with some other opinions.
T
s3rdy
s3rdy's picture
#Tonestar what Sonos unit are you thinking of? I will go check it out!
