Media Server on Panasonic Viera - problems playing any !
17 replies [Last post]
Portoman's picture
Hi
I've been told that I can use programmes such as Serviio, Mezzmo and even Windows Media Player to stream media from the pc to the tv.
I've downloaded Serviio and also tried to configure WIndows Media Player (through a tutorial on You Tube) to do this, but when I select "Media Server" from the Viera Tools options, it only finds my wireless box and nothing else.
Is my Viera not one of the models that can do this ? Or what I am doing wrong ?
Any help is appreciated.
AnotherJoe's picture
RE: Media Server on Panasonic Viera - problems playing any !
You'd get more replies if you actually posted what model your tv is  banging head against wall
__________________
Server Synology 12Bay DS2413+, Synology 8Bay DS1812+, Sky+HD
Lounge Samsung UE55D9000, Denon DBT-3313, Onkyo TX-NR5009, Tannoy Arena Highline 500 LCR, ACRyan playon!HD mini2
Reception Samsung UE46C8000, Panasonic BDP310, Sony STR-DA5400ES, KEF2005.3, ACRyan playon!HD mini2
Portoman's picture
It's a Panasonic Viera TX-L42ESB
amcluesent's picture
Firewall on your PC may be blocking incoming connection requests
__________________
Audio Analogue Paganini 24/192 REV2.0, Squeezebox Transporter, Myryad MT100, Audio Analogue Maestro Settanta REV2.0, Sonus Faber Guarneri Homage  · Squeezebox Touch, Quad FM4\34\306, Sonus Faber Concertinos · Squeezebox Controller
Processors in tv are weak imo. I gave up using tv for anything internet/streaming related.
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic TX-P42G20B., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
Portoman's picture
Hi
I've tried it with the firewall off and it doesnt make any difference. It is frustrating as I hear good things about Serviio. Also, I;ve noted that Panasonic mention Twonky streamer but it seems you have to pay for the license, which is ridiculous - do you think that Panasonic tvs only work with Twonky though, as it's strange how it is recommended in the actual manual.
You need to make sure all devices on your network are allowed to access the pc
Try this and report back.
On the windows pc you want to stream from....
Control Panel -> Network and Internet -> Network and Sharing Center -> Advanced sharing settings
- Make sure Network Discovery is on.
- Under media streaming, click on choose media streaming options
Change show devices on to All Networks and click Allow All. If a popup appears select Allow all computer and media devices
Click OK, exit
__________________
Portoman's picture
Okay I've tried to do that - I'm using Windows 7 by the way - but when I click on the options to turn on Network Discovery, then save changes,  it doesnt appear to acfually turn it on, as when I go back into it to see if it anything has been altered, I find that the Network Discovery has reverted to "off" and the same with any other settings that I have put to "on".
After turning on network discovery click save changes at bottom.
After entering the  'choose media streaming options' screen after selecting 'all networks' and  'allow all', click next, make sure music, video etc are set to shared and then click next and then finish on final screen.
I'm using Win8 and they may have changed the windows slightly - but I'm sure you get the gist.
__________________
Portoman's picture
Okay this is what I'm finding :
after scrolling down to "media streaming"  ( which says is "off")... "choose streaming options"..... there is a small box saying "name your media library" and I'm supposed to type something...directly under that there is another box that says "show devices on" which I can click on to choose a device but no devices are listed.  To the right 2 more boxes "allow all" and "block all" and below them there is "okay" and "cancel". The thing is, the "okay" button is never highlighted ,only the "cancel" one. So though I can click on "allow all", the "okay" button never becomes clickable, What I am supposed to type in the "name you media library" thing ?
You can call the library anything you like - mines called PCMediaLibrary
Have you turned on Network Discovery and clicked save changes?
If you have and no devices are showing on your pc then:
Have you connected you tv to your network? Wired or wireless? Run the network connection test on your tv.
It sounds like your tv is not on the network (or discovery is turned off) if your computer is showing no devices.
__________________
Portoman's picture
Okay this is the latest : somehow my tv has now managed to pick up Serviio from my computer = good of course. The problem is though, when I select Serviio I keep getting an error message "connection to the server" failed.
Im not familiar with Serviio. Is the server running on the pc ok? Is the network connection on the tv working? Is the TV now allowed to acces the PC ?
Try using PS3 media server. http://www.ps3mediaserver.org/
When you run it add your media location in the Navigation/Share settings tab, clicks save, and then restart server
__________________
Portoman's picture
I think Serviio is just a popular media streamer. The tv picks it up - which shows the pc is transmitted the media to the tv and it is picking it up - but that's all it does. When i click on Serviio, it says "connecting" and then "cannot connect" - so does that mean the signal isn't strong enough ?
Sounds to me more like it cant connect to the server because either the server has stopped, or it lacks permission.
I cant help with Serviio setup and settings - thats why I suggested PS3 media server.
The initial help I gave of allowing network access to all devices HAS to be done regardless.
__________________
Portoman's picture
Ok\ay Ive downloaded the PS3 thing. It is running on the computer but isnt being detected by the tv as yet - on the "status" tab it says "no renderers were found" and a big X is displayed.
