3 posts / 0 new
Last post
stephen_matthews_uk's picture
Last seen: 2 years 6 months ago
LINDY USB Portable Wireless Audio System
Hi, looks cheap enough and gets around my having more files on my PC than I can fit on my iPod Classic (docked in a PURE iDock) BUT, this is limited to the 16bit and I have some 24bit files, anyone any idea what will happen if I try to stream those? Silence? I've asked the importers but they've ignored me ...
RE: LINDY USB Portable Wireless Audio System
this is the boy http://www.amazon.co.uk/LINDY-Portable-Wireless-Audio-System/dp/B00475XR9U/ref=cm_cr_pr_product_top
Scissor_digits's picture
Last seen: 6 months 4 weeks ago
The manual says '48KHz with 16-bit downstream' and 'Supports LPCM and Compressed format 16-bit 2-channels' which suggests it won't support your 24-bit files
http://www.lindy.co.uk/downloads/20519v1.pdf
There is an Ask a Question link on the product page. To remove all uncertainty I suggest asking Lindy directly
http://www.lindy.co.uk/usb-firewire-c4/usb-converters-c213/usb-to-audio-interfaces-c1503/usb-wireless-audio-sender-p2742
Log in to post comments
