3 posts / 0 new
Last post
stevenn21's picture
Last seen: 2 years 9 months ago
help needed with playlists on the ca np30
im having trouble getting playlist to show up on the np30
all my music is in music folder on my pc.
i created playlists with playlist creator 3.6.2 and saved them to Playlists in the root of the music folder but they dont show up in the streamers ui when searching advanced search>folders and filenames> music>playlists. it shows up as [EMPTY] when searching with the remote.
i heard you have to use the app to get playlists to load but when i try to access the playlists folder in music with my smartphone the loading circle just spins on the screen it wont go into the folder this app is so buggy its ridiculous.
any help would be appreciated Steven
stevenn21's picture
RE: help needed with playlists on the ca np30
SOLVED
Bgcarter's picture
Last seen: 2 years 4 weeks ago
Can you please tell me how you solved this? I have the same.
Log in to post comments
