Does Network Audio Player add value to Yahama RX-A1020
1 reply [Last post]
DigitalPeteDevon
DigitalPeteDevon's picture
I did away with my CD player a year or so ago (being told my expensive player could 'no longer be repaired' had a lot to do with this), and now play FLAC from the Lacie Lacinema through Yahama RX-A1020, either by Lacinema playing to Yam over HDMI or by YAM playing off the Lacie media server via Ethernet. I have to say I can't hear the different between these two play modes, I guess because buffering, D/A etc is done in both cases by the YAM. Having said that, the YAM sometimes cannot see the Lacie server and the YAM GUI is pretty rubbish so normally the Lacie plays. Either way the Lacie doesn't do much, all the heavy lifting is done by the YAM.
My Question is this: Would a 'premium' Network Audio Player make a noticable difference to the music quality with my existing amp and speakers ? If so how much would I have to spend before I noticed a difference ? I know I should go to the shops and listen but I hate HIFI shops as much as I dislike hairdressers, and they wont have my pre-historic speakers anyways.
__________________
Lacie Lacinema Classic - HDR FOX T2 - Sony BDP S590
Yamaha RX-A1020
Monitor audio Gold REF X 2, Monitor Audio CPW X 3, B&W PV1D
Pioneer PDP 436 XDE
jacobmorrison
jacobmorrison's picture
RE: Does Network Audio Player add value to Yahama RX-A1020
It's doubtful. Any streamer, even if it had it's own high-end DAC, would still be relying on the pre/power stages of the Yamaha amp and it's here that the music is probably getting lost. I would suggest a cheap dedicated stereo amp running from the front L/R pre-outs of your yamaha, and a separate DAC connecting this stereo amp to your LaCinema would transform the sound, but you'll be adding boxes, cost, and complication. Alternatively I understand the Onkyo 8050 network receiver is very good value. Add this to your Yamaha's pre-outs and you could get rid of your LaCinema as this amp will stream your FLAC files over the network and has a good quality DAC included.
__________________
Pioneer Kuro 4280 / Oppo 93 / Yamaha RX-V771 / Leema Pulse / Musical Fidelity V-DAC II / Pure i-2O digital dock / Project Xperience-Goldring 1042-Project SpeedBox II/ Monitor Audio BR5-2-BRLCR / Sky+HD / Musical Fidelity HPA100 - AKG Q701
