Advice needed - Starter for 10
3 replies [Last post]
Audiophobe
Audiophobe's picture
I'm looking for a new Hifi.  Currently have old Technics seperates system (which is very good) but doesn't give the modern day flexibility plus it's basically a single CD (Ipod is more flexible), Dual Cassette (obselete), AM/FM tuner (would like DAB) all coupled with good amp and good speakers.
Am just importing all CD's and music to iTunes/Digital media with the goal of having one music library that I can maintain and backup.  I have ipods, ipad so I want to be able to be lazy, sit in the armchair, select music from ipod/ipad and play through hifi system.
The other criteria is I must have a DAB tuner rather than a sole internet radio option.  I don't want to listen to DAB through internet as that's using internet download for something that I could get "free" through the airwaves.
Any good solutions/setup advice.  Happy to keep existing amp and speakers and upgrade seperates if theres a good solution or alternatively exchange the lot.
Mark
BigH
BigH's picture
RE: Advice needed - Starter for 10
How about MArantz 603, it is all in one system which is only £350 at moment, you need to buy speakers as well, has DAB, cd, amp etc.
__________________
Marantz 63SE AVI ADM9RSS
amcluesent
amcluesent's picture
dup.
__________________
Stello CDT200, Squeezebox Transporter, Myryad MT100, Audio Analogue Maestro Settanta REV2.0, Sonus Faber Guarneri Homage  · Squeezebox Touch, Quad FM4\34\306, Sonus Faber Concertinos · Squeezebox Controller
amcluesent
Depends on your budget of course.
TEAC CR-H700DAB mini-system has DAB and Airplay at around £500.
__________________
