Zeppelin Goes Live!!
I have just started getting small, but noticable electric shocks when turning my Zeppelin on and turning volume up n down!! Anyone ealse had this?? I bought it about 18 months ago so not under warrenty anymore
, will just use remote in future!!
Had mine for about 4 months. No problems. Use the remote!
Just a thought check your warranty - mine has a two year warranty. Their customer support people are very helpful, but will ask for proof of purchase - either a receipt or credit card/bank statement
pheaton:Just a thought check your warranty - mine has a two year warranty. Their customer support people are very helpful, but will ask for proof of purchase - either a receipt or credit card/bank statement
If thats the case, I best get looking for my reciept and see what the B&W team can do!!
mine did but only when plugged in to a 4 gang extention lead - wall socket fine - hows your connected?
matengawhat:mine did but only when plugged in to a 4 gang extention lead - wall socket fine - hows your connected?
Plugged straight into the wall!!
Sorry to hi jack your thread guys but I am thinking of buying the Zepplin for Xmas how good is it. The room its going in is 5m x 4m will it fill the room with big sound. Thanks for any feedback
hilly10:Sorry to hi jack your thread guys but I am thinking of buying the Zepplin for Xmas how good is it. The room its going in is 5m x 4m will it fill the room with big sound. Thanks for any feedback
I do love the Zeppelin, and think its a great way to use your ipod indoors, but I find the speakers are to close together to 'fill' a room, but does go loud enough for a enjoyable listen. I also find if its positioned in a corner, it can get a little too bass happy. All in all, it is well worth considering.
Thanks for the info. Going to get it at the weekend
Can anybody tell me what I am doing wrong. Connected laptop tp Zeppelin via USB in laptop with the sq pin into doc (the one that goes into my printer it fits) I get no sound is it the right lead or do I need a special one
The USB is only there for firmware updates, not for audio connectivity.
Thanks Andrew I found out a little while after posting. To stream from computer its just a AUX jack plug.
I suspect rubber soles and man-made fibres...
Cambridge Audio StreamMagic 6 | 751BD | 651A | PMC DB1i | A secret shiny box | Sonos Play:3
Moderator. mail: john.duncan.whf at the mail of g dot com
