wav files from phone/Ipod via usb to DAC - views, opinions, comments please??
43 replies [Last post]
Gerrardasnails
Gerrardasnails's picture
I plan on using my mobile phone and new DacMagic together. Is usb anywhere near as good as coaxial?
__________________
Screen - Samsung UE46D8000.  Sources - Dell Zino HD 410; Sky HD; Sony BDP S550; Wyred 4 Sound DAC1.  Amps - Yamaha RX-A3010; SimAudio Moon I-3 RS.  Speakers - Vienna Acoustics Mozart Grand; Vienna Acoustics Waltz Grand centre; Proficient Audio W690 rears; Monitor Audio RSW12.  Cables - Van Damme Blue 4mm speaker cable; Townsend DCT300 and Atlas Voyager interconnects; Van den Hul Optocoupler.
zzgavin
zzgavin's picture
Re: wav files from phone/Ipod via usb to DAC - views, opinions,
Octopo and the Cambridge Audio CEO both recommend S/PDIF (coax and optical) over USB. Over short runs it is probably not a huge difference. Hard to see how you'd get anything else than USB from a phone though.
Gerrardasnails
zzgavin:
You're right, no choice other than usb for the phone but lossless to the dac should sound better than straight to the amp which is the only alternative. I was wondering how others find the sound.
__________________
pudley
pudley's picture
I doubt you will get an audio stream digital or otherwise from the mobile phone.
Most mp3 players have USB slots, but that does not mean a digital output for music playback, only for getting data off and on.ÿ
Gerrardasnails
pudley:
I'm not sure I understand what you are saying. Currently I can run my phone to my amp with the cable that came with the phone - rca one end and the phone adapter the other. Are you saying that it won't play music through the usb cable? If it doesn't - I will have to buy an ipod which I will probably make more sense anyway.
__________________
John Duncan
John Duncan's picture
Can't speak for your phone, but I'd be surprised if you can get a digital audio out from the ipod either. This is for the DACMagic yeah?
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
pudley
pudley's picture
Gerrardasnails:
pudley:
AFAIK there are no mp3 players that will play from their USB slot. The iPod would require you also bought a Wadia transport.
Gerrardasnails
JohnDuncan:
Indeed. Oh well. How do you connect an ipod to the DACMagic then?
__________________
John Duncan
You get a Wadia iTransport thingie
__________________
Gerrardasnails
JohnDuncan:
Cheaper for me to buy a modest laptop and send songs through that.
__________________
John Duncan
Or airport express, which is what I'm going to do - is a pain remote-controlling it, but will probably go down the iPod Touch route.......
__________________
professorhat
professorhat's picture
JohnDuncan:
I have to say, since getting the Remote software installed on my Touch, I do use this feature quite a lot now. Not to mention numerous other applications I use on it like Golf Tracker to keep a track of my golf score improvement, Live Trains, DVDDash, plus numerous games.
John Duncan
Yeah I tried....um......(has to look).......Salling Clicker which works fine provided I stand in the hall........does Remote work over the network or is it bluetooth as well (which I presume is the problem I'm having with Clicker)?
__________________
Gerrardasnails
JohnDuncan:
I just called RS and will be popping down to the local branch at lunchtime to place my order!! I could have one tomorrow but def by Friday!!
__________________
professorhat
JohnDuncan:
Remote works through the wireless connection created by the Airport.
John Duncan
Gerrardasnails:
Ooooooo
__________________
