Onkyo ND-S1 : What is the final verdict on iPhone4 / 3GS compatability?
Hi, I read about this query on iPhone4 / 3GS compatability with this dock unit under thhis website Review section. I am a bit unclear of what is the final verdict on this compatability issue. Can the dock accept signal from an iPhone? Any has tried it?
I have the dock and it works fine with my iPhone 3G and my Friends 3GS. Cannot comment on the iPhone 4 though.
The only thing I would be concerned with at present is that recently (I think from the 4.0 firmware upgrade onwards) there has been an issue with the iPhone and digital docks. You should be able to google this. I do not think this has been fixed by Apple yet.
Mine still works fine as I have simply not 'upgraded' the firmware.
El Hefe:Any takers?
WHF? Clare? Andrew? JD?
I'll ask Onkyo this morning - hope they've made it through the snow (I know they were all sent home early on Friday!)
Thanks Clare for the follow up.
Messiah:I have the dock and it works fine with my iPhone 3G and my Friends 3GS. Cannot comment on the iPhone 4 though.
Thanks Messiah for your comment. Yes, it seems to have some issue with the latest firmware. Hope to hear the feedback from Onkyo via Clare tomorrow.
They're hoping to get back to me this afternoon.
I had the issue that you refer to with IOS 4 on ipod touch 3G with the ND-S1. However since 4.2 became available all of the jitter / popping issues have been resolved.
I can confirm that the problem was not with the ND-S1 as I had mine exchanged and I was experiencing the same issue. I only became aware that it was definately an Apple issue when I started to also have the same issue in the car that also uses the digital port, although through headphones the ipod sounded fine.
Yep, here's the response direct from Onkyo:
"The Onkyo ND-S1 was certified at launch for:-
iPod touch (1G and 2G), iPod classic, iPod (5G*), iPod nano (1G*, 2G, 3G, and 4G)
So the ND-S1 is not officially certified for the iPhone 3GS/4 (and Onkyo has never claimed otherwise) though in practice it will play back content from them and charge them... but you will invariably need to have the device in Airplane mode to avoid pops and clicks (metal objects within the vicinity of the iPhone's antenna can act as a ground plane).
BTW, there appears to have been a separate issue affecting Apple devices and all digital docks in general but iOS 4.2.1 appears to have remedied that.
Clare,
Thanks for the update. Its good that Onkyo provided that clear explanation. That has saved me 150 quid.
Clare Newsome:
Personally I have always used it in 'normal' mode and it has been fine, no pops or clicks.
You certainly know when you get a call too!
Any takers?
HiFi: ClearAudio Concept TT, Musical Fidelity M6i and M6 DAC, M1s (CDT, CLiC, ViNL), Onkyo TA2600, SONY MDSJA20ES MDP, ProAc D18 with full Siltech cabling.
HT: Samsung UA55B7000 LED, OPPO BDP 95-EU,Marantz DV4003, Yamaha RX-V2067, Philips DVDR7300H, Infinity Primus Center, Wharfedale WH2, SW15 Sub, Mission M34i with full QED cabling
Bedroom: BRIK Audio BT Stage, Bose WAVE Music Sytem III
HeadFi: Alessandro Grado MS Pro, Bryston BHA-1 headphone Amp.
Office: iTunes, UD100 USB DAC, Bose Companion II, Musical Fidelity HPA headphone amp, Bose Over The Ear
