Itunes doing my head in - Basic question, apologies now.
Right,
Still a bit new to this, even though i have been ripping cd's for ages now.
How do i sort out my itunes libary in simpleton terms ?
If I rip a cd / album by one artist who has alot of "Featured with" tracks, how do I get them consildated to show those tracks as one album ? What setting do I need to apply please ?
For example - any hip hop album - say Kanye West for example - dont want seperate individual tabs for one album ? Im sure you know what I mean but its doing my head in ?
I do not want a complicated, pay for this tool answer please.
Getting on a bit so please keep it simple.
Thanks.
Not really,
Appreciate the prompt reply but thats not what I mean. Perhaps Im not explaining enough or I just have really bad ocd !
When I go to Itunes on my pc, I always select music and have quite a few albums artwork displayed of one album, then aload of itunes music note symbols with tracks on the same album but featuring different artists. Basically I dont want them seperate but in the one tidied gracenote artwork album single listing. Few, that was hard work.
Hope that makes more sense ? Had a few !
Right it's long hogg but I think it's possibly the simplest way,
Select what songs you want to put into a genre, press 'control i' then type in the album name for that artist. If the Album artists conflicts with the album name then you need to delete that too.
This sounds like a similar isue I had with J River - for example an album of say 20 tracks by various artists was being catalogued as 20 separate albums. This was because some compilation albums file names are artist/track.flac whereas others are various/artist/track.flac.
Is this what you are saying?
Yeah I guess so but your getting technical now !
Actually no.
Its just one artist / one album but being listed as loads of different tracks ? Maybe thats how it should be but its not how my ocd likes it ! I want one album to index as one album regardless of how many "guest artists" are featuring on one album ? Now do you get what I mean ? God im getting old !!!
Right dude you gotta hit 'control A' for all those tracks you want selected then just pounce on the rest of the tracks, I'm listenting to them now. Music is special.
Octopo.
Thanks, I think you understand, even If I dont, will give it a try.
My girlfriend posted that but it's true........
Your girlfriend is indeed right so thanks, finally sorted.
Control i or get info - Duplicate artist name in artist album. Job done.
Give her a big kiss with that horrible moustache as a thanks ! Cheers.
I spent Two hours last night trying to do the same thing, my songs from albums all over the place, I was listening to Clubland 18 on shuffle and a couple of songs in Shirley Bassey started singing, thank god my mates were not in the Van.
I went to file and clicked on get info and did it manually, panefull !! There must be an easier way probably through playlist.
Assuming you are on a Mac, select all the album tracks and use Command I (on Windows use whatever command to get the info page open).
In Album Artist type in the Main artist name and it will populate all the tracks.
Then in the main iTunes window select "Album by Artist" as the sorting method. That should do it.
If not, the other method to fail back on is to select all the tracks and tick "Part of a Compilation" in the options page.
DavieCee:the other method to fail back on is to select all the tracks and tick "Part of a Compilation" in the options page
Not a Mac user but again another easier option that I knew nothing about.
Thanks for the help everyone and have a good 2011.
you are right i-tunes is very user un-friendly. Anyone have a good alternative software product that is compatible with i-players?
Sounds to me like you want to create a playlist that'll be read worldwide like...
