itouch to truck stereo
1 reply [Last post]
Mike_Schmidt
Mike_Schmidt's picture
so for the first time i hooked up my itouch via analogue to the mini jack but the problem is that is sounds really bad even through purchased itunes and wav files. It sounds to loud and pushes my speakers in my titan to the max even on 4-5-6 usually on CD its around 11-12. Its a monster cable, so any ideas what the problem could be?
fatboyslimfast
fatboyslimfast's picture
Re: itouch to truck stereo
Hi Mike,
Does the monster cable use the dock port or the headphone jack? If the latter, turn the volume down on the ipod!
If not, I'm a bit stuck - the Belkin AutoPilot I have has a "high" and "low" output level - the high suited my sony, but the low is necessary for my Toyota...
__________________
Sources: Technics SL1210Mk2 with Denon DL110/AT-95E, Mac Mini, Virgin V+.
Amplification: Cyrus 2.
Speakers: Mordaunt Short MS20i Pearls with Fisual Super Pearl 2.5mm cable.
Other kit: More than I should have. My loft is creaking.
