ipod classic
Fri, Jan 4 2008, 1:51PM
I'm thinking of buying a new ipod but have read some indifferent reveiews regarding the classic. Mainly focussing on the volume cap and the interface with itunes which apparently can be very slow and unreliable. I wondered if the team had encountered any of these problems and specifically if the volume cap would pose a problem when using a dock.
Also how does for example the classic 80GB compare to the previos 80GB model and is there any difference in sound quality between WAV and lossless?
Many thanks
- Login to post comments
The volume cap won't matter as that is for the headphone amp and the dock will draw audio from the line-out which is fixed volume anyway.
