iphone itunes to home theater
6 replies [Last post]
Mike_Schmidt
Mike_Schmidt's picture
iam guessing a idock and aset of rca's but how do I change songs without getting off the couch? Thanks
nads
nads's picture
Re: iphone itunes to home theater
with difficulty. play it from your PC and use your iPhone to control it.
but i think there is a new function in the latest OS that will let you stream to some other box which will then allow play back on the amp.
__________________
Not a HiFi Nut. Just has a pile of Nads.
Andy Clough
Andy Clough's picture
Yes, if you have a new Apple TV (£99) you can connect that to your AV receiver, use it to stream iTunes from your iPhone and control playback through Apple AirPlay on the phone. Or you can use an Apple AirPort Express.
__________________
Andy Clough is Brand Editor of What Hi-Fi? Sound and Vision and whathifi.com
pwiles1968
pwiles1968's picture
PC/iTines to HiFi/AV is beeen discussed in another thread at the moment you may find some usefull info - http://community.whathifi.com/forums/t/542530.aspx
__________________
Stereo -1st Gen Apple TV with ATVFlash & 1TB HDD > Audiolab CDQ > Bel Canto Evo 2 > B&W 805s
Graham_Thomas
Graham_Thomas's picture
Mike_Schmidt:
You mean with with 2 babies on your knee - you need a remote my boy! Smile
__________________
Mike_Schmidt
Sorry for the late response guys but I have been busy. Looks like apple TV might be the way to go
eremis6
eremis6's picture
If you dont want to spend that much, this would be a cheaper but slightly less practical solution. http://www.richersounds.com/product/ipods-docks-accessories/roth/dock/roth-dock
