FLAC on iPhone4
Thu, Oct 14 2010, 3:04PM
Is anyway to play FLAC files over UPnP server on iphone? Ive got loads of SACD / FLAC files on my Synology DS210J NAS but wont play on iphone4
Ive got ability on the Synology to transcode FLAC files but when selected they still dont show up on media server
Thu, Oct 14 2010, 6:53PM
#2
Thanks, ill give that a go
Fri, Sep 2 2011, 8:13AM
#3
[Spam post removed by Mods]
Fri, Sep 2 2011, 10:43AM
#4
I'm interested in your SACD files. Can you rip SACDs? Didn't think it was possible.
I have ripped quite a few SACDs but they were all hybrid SACDs of which the CD layer can be ripped.
If you need to do batch conversions from FLAC lossless to Apple Lossless on a Mac you can use Max. http://sbooth.org/Max/
It will keep all metadata.
I can play mine from my HP Data Vault via the PlugPlayer app, which I either listen to on headphones, or via bluetooth on my Marantz receiver. It was very easy to set up, but if you start using your phone to do anything else it tends to make the sound drop out for a second or two.
Any questions, I'd be pleased to help.
Audiolab 8200CDQ Roksan Caspian M2 Power Amp Dali Ikon 6
Sony KDL46HX853 Humax Fox T2 HDR Sony BDP S570 Yamaha RX 3010
Other Stuff - HP Data Vault Squeezebox Touch Asus Xonar Essence AKG K271 JRiver Media Center
