Converting DVD to ipod
4 replies [Last post]
legitum
legitum's picture
Does anyone know of any legitmate software that would allow me to transfer DVD films to my video ipod? I tried downloading a piece of software online from www.makayama.com which claimed to be able to do it, but it caused a virus on my computer. I also downloaded Tubehunter which had similar claims, but again, it hasn' worked. Any help would be gratefully appreciated. Thanks
ChalkyWhyte
ChalkyWhyte's picture
Re: Converting DVD to ipod
Hi there, have you tried a program called clonedvd mobile it converts movies for many portables players including ipods an archos players. i have used it and found it easy to use and the quality to be very good. I'm sure u get a free trial aswell so worth a try.
Clare Newsome
Clare Newsome's picture
Hi there,
Amazon stocks a range of software that'll let you do this - check out the user reviews on this example for what's involved - but do remember that the vast majority of standard DVDs are copy-protected and it's illegal to make copies.
However, there have been various cases rumbling through the law-courts re making copies of DVDs you already own as back-ups - so as long as these are for your own personal use, and not being shared, you're probably on safe ground. (Which incidentally you definitely are with CDs - as long as copy is for your own use, it's fine).
__________________
Group PR Manager - Computers Unlimited;
Former Group Editor of What Hi-Fi? Sound and Vision and Whathifi.com
Twitter: @ClareNewsome
Mr.H
Mr.H's picture
No need to spend any money. Just get yourself Handbrake, an open-source DVD to MPEG-4 converter.
Will Harris
Will Harris's picture
Outstanding. If that doesn't work, I have a piece of software at home, DVD Audio ripper or something. Creates mp3 files from DVDs. Works really well. Have no recollection of where I got it, but if you google you're sure to find something that will work. Handbrake looks good. I might start using it. I used the one I have to turn all my live U2 DVDs into music for my iPod.
__________________
JVC DLA-HD1 -- OPPO BDP83 -- ARCAM AVR600 -- DALI Helicon 800 Mk1 -- BK Monoliths FF and DF
