ATRAC vs AAC (another format deathmatch!)
3 replies [Last post]
Strodo
Strodo's picture
Which provides the best sound quality:
 AAC 320kbps
or
ATRAC 352kbps
Will Harris
Will Harris's picture
Re: ATRAC vs AAC (another format deathmatch!)
Mate, if you can hear the difference, then you tell me!
__________________
JVC DLA-HD1 -- OPPO BDP83 -- ARCAM AVR600 -- DALI Helicon 800 Mk1 -- BK Monoliths FF and DF
Halloway
Halloway's picture
 I remember ATRAC was always being slated but I thought the quality wasn't bad.  Trouble is I don't know how one could do a sensible comparison as I don't believe there are any ATRAC encoders available for PC (correct me if I am wrong).  Certainly, AAC at 320Kbit/s is going to be pretty good.
ranjeetrain
ranjeetrain's picture
A lot depends on the Encoder and encoding options as well. Also, if
you spend enough time experimenting, you will find for some tracks 128
kbps is as good as 320 kbps. Depends on a lot of factors.
My
advice is: select one format and stick to it. Choose VBR with High
quality if your encoder has them and choose 256 kbps as lower boundary
and highest available as upper boundary. The best one time setting.
