arcam rdock advice
1 reply [Last post]
mr exclusive
mr exclusive's picture
i have a bose wave system is it possible to connect the rdock via aux. If so r the cables supplied with the rdock worth keeping if not what r the best cable for it? thank you for yr time
Andy Clough
Andy Clough's picture
Re: arcam rdock advice
If the Bose Wave system has a standard set of phono in sockets then yes, you should be able to connect the r-Dock OK. The cables supplied with the r-Dock should be fine.
__________________
Andy Clough is Brand Editor of What Hi-Fi? Sound and Vision and whathifi.com
