Anyone got an Arcam rDock?
I've just picked up an rDock from the local shop, the (shocking) instructions seem to imply there should be some sort of insert that fits into the docking well, presumably for my particular type of iPod - there are none of these in the box.
Is this the case? Am I missing something before I get back back onto the shop and make a fool of myself demanding something that doesn't exists!
Well, the brochure says it has
"1x iPod universal well suitable for all iPods latter (sic) than 4th
generation including Mini and Nano",
which might explain why AC's 3G one doesn't fit too well.
But I see what you mean about the manual: this
does seem to suggest some kind of insert is supplied to be inserted in the well before you place the iPod in the unit.
I think a word with your retailer, or with Arcam, might be in order...
Just had this official reply from Arcam's PR chap:
"All iPods since Apple introduced the Apple Universal Dock a few years ago come with the appropriate adapter in the box. So if you buy a nano, you get a nano adapter etc
The Arcam rDock then uses the Apple Universal Dock adapter, into which the adapter supplied with your iPod fits.
For extras, just look on the Apple Store site."
Of course, as Andrew correctly points out, if you have a pre-4G iPod (as I do), you won't have an adapter.
I have an rDock too, and like you it came supplied without any kind of adapter, so my iPod (G3) just sits rather loosely on top of the connector. Works fine.
Andy Clough is Brand Editor of What Hi-Fi? Sound and Vision and whathifi.com
