all in one for itunes streaming
1 reply [Last post]
knacker
knacker's picture
any recommendations for an all in one to enable me to play streamed files from itunes in a different room? Logitech boom is any good or any alternatives? It does not have to be fantastic sounding as for a kitchen and would like a compact design if possible
I would ideally like to to be mac and or pc compatible and have a BT wireless router.
__________________
Cyrus 6SE CD,Cyrus 6XPD, PMC DB1,Cyrus Interconnect, BIwire speaker cable, Mac Mini,ipad2 & itunes
professorhat
professorhat's picture
Online
Re: all in one for itunes streaming
If it has to be all-in-one, anything with built-in Airplay is what you need e.g. the forthcoming B&W Zeppelin Air. If you can bear it not being all-in-one, you can essentially use anything with a line-in input and an Airport Express e.g. most powered / active speakers offer this functionality.
Not sure what you mean by being Mac or PC compatible? If you're playing streamed tunes from iTunes, then the OS that iTunes is running on shouldn't really matter.
