Sky Wireless Connector
Fri, Oct 5 2012, 8:47AM
I looked at buying one from Sky last week and it was £59.99.
Its now just £9.99
Fri, Oct 5 2012, 1:05PM
#2
Sky have introduced a new 802.11n Wireless Connector, the original only being g, so maybe worth checking which model they're supplying (wondering whether they're just clearing old stock) at that price, especially if you intend streaming HD content.
Fri, Oct 5 2012, 1:29PM
#3
I've ordered one anyway, so thanks richardw42. If it proves not to do what's promised, the DSR should cover the return.
Fri, Oct 5 2012, 4:13PM
#4
Petherick - send it back NOW. With yr avatar you certainly wont be satisfied with it !
Fri, Oct 5 2012, 4:39PM
#5
There doesn't appear to be any specs (n or g).
If it doesn't perform, it'll go back.
Fri, Oct 5 2012, 4:40PM
#6
Although for a tenner, I prob wouldn't bother.
- Login to post comments
Good spot - link: http://www.sky.com/products/kit/wireless-connector/
