In-door ariel
I bought a freeview hd box but there's no ariel in the room.
So I was wondering whether one of those in-door ariels would do the trick.
The freeview box is:
& is connected to one of those old CRT TV's
I want something which will do the trick at a cheap price (maybe a good review to it's name & say around £10 mark).
Anyone offer any insight on this forum? thanks.
I would agree on the other readers choice, I use this one at work for demonstration teaching purposes. All indoor aerials are a compromise unless living close to transmitter, but these are easily the best I have found so far!
And what is needed is an ‘Aerial’. Ariel used to be a motorcycle and Hebrew for Angel or Lion of God!
Thanks for improving my vocab,
Are the 27770R & 27769r the same?
I found this glistening review of the 27770R:
http://www.techradar.com/reviews/audio-visual/av-accessories/philex-digitop-27770r-678486/review
- Login to post comments
You need to be in a very strong signal area firstly, and if you are, try this http://www.amazon.co.uk/digiTop-Amplified-Performance-Freeview-Wideband/dp/B001ACV7E0
But check your signal strength first, because if it's not good, you're wasting your time and money.
LOUNGE: PANASONIC TX-P50GT50 / PANASONIC DMP-BDT120 / SKY HD / SONY STR-DA2400ES / Q ACOUSTICS 2020i (front) / Q ACOUSTICS 2020 (rear) / Q ACOUSTICS 2000Ci / Q ACOUSTICS 1000Si / PRO-JECT DEBUT 3 / WD MY BOOK LIVE
BEDROOM: SAMSUNG LE32C450 / SONY BDP-S360 / ECHOSTAR HDS-600RS
