6 posts / 0 new
Last post
lobby's picture
Last seen: 3 years 1 month ago
Dali Ikon 6 5.1
Avland are selling Dali Ikon6 for £1699 light oak only bargain
Anonymous's picture
Re: Dali Ikon 6 5.1
I'm so torn between this and an RS6 package!!!!  My only problem is I can't wall mount the rears Sad.
Any one know if it is at all possible to stand mount the rears from the Dali Ikon Package?
Gerrardasnails's picture
Last seen: 2 years 6 months ago
Re: Dali Ikon 6 5.1
Aeis:
Get the RS1 speakers as your rears - these are award winning bookshelf speakers from the RS range. Try your local Sevenoaks store and they will do a deal with you.
fr0g's picture
Last seen: 4 months 2 weeks ago
Re: Dali Ikon 6 5.1
Aeis:
probably not, but the Ikon 1's or 2's would slot in nicely.
Anonymous's picture
Re: Dali Ikon 6 5.1
the ikon 1's are the same price as the surrounds
Anonymous's picture
Re: Dali Ikon 6 5.1
I have the 6 5.1 and you don't have to wall mount the rears. If you are wall mounting, then you literally put a single screw in the wall and hang of that, otherwise you can bookshelf mount them no problem. All you'd need is a little blue tak. They're not so narrow they won't stand up or might wobble. They're heavy and not that small at all. So quite a flexible speaker. The package is brilliant and a bargain at that price.
Log in to post comments
