Will the Pioneer BDP-LX55 be Muti Region ?
I have one of these on order and wonder if this unit will be Multi region for standard DVD. I currently have a TOshiba DVD player in my set up simply because it will play region 1 discs. If the Pioneer will do this I can free up some space..... CHeers
A hardware fix is not necessary to make a player multiregion for DVDs. As advised, ask your dealer. If they don't make it multiregion, it may be worth dropping an email to this seller on eBay: http://www.ebay.co.uk/itm/Pioneer-DVD-Blu-ray-player-multi-region-hack-remote-/120651207588?pt=UK_AudioTVElectronics_Video_DVDPlayers_Recorders&hash=item1c175f53a4#ht_2880wt_922
Alternatively, replace your region 1 DVDs with region 2's from ebay/car boot sales, may work out to be the cheaper alternative if you don't have that many region 1 DVDs.
Apologies, my mistake.
- Login to post comments
It won't be multi region as standard, so you need to check with the supplier.
They could probably make it multi region for you for a fee, as it will need to be a hardware fix, rather than done by a remote hack.
Others may know better than me about the cost, as my BDP-320 came already multi regioned by my supplier.
LOUNGE: Panasonic TX-P50GT50 / Panasonic DMP-BDT120 / Yamaha RX-A2020 / Q Acoustics 2020i (front) / Q Acoustics 2020 (rear) / Q Acoustics 2000Ci / Q Acoustics1000Si / Pro-Ject Debut 3 / Sky HD
BEDROOM: Samsung LE32C450 / Sony BDP-S360 / Echostar HDS-600RS
IN THE ATTIC: Cambridge A4 Integrated Amp (not working) / Technics SL-PG 490 CD Player / Teac V-1050 Tape Deck / Morduant Short MS-20i Pearl Edition Speakers
