Will Pioneer VSX-920 give enough oomph to power Dali Suite 2.8 speakers?
15 replies [Last post]
dougolada
dougolada's picture
Hi all,
I have been looking out for an AV receiver and noticed Richer Sounds are selling the Pioneer VSX-920 for £299.95. Looking at the Pioneer website for some more info, I see that they have a promotion for £100 off! That means I could get the amp for £199.95, which seams like an absolute steal!
To my question: will the amp give enough oomph to power my Dali Suite 2.8 speakers? I have 4 of the beasts which are rated at 4 ohms and Dali recommend amp power of 30-160W. The amp has a power output of 140W per channel at 6 ohms. Would it be ok to run my Dali speakers on this amp? I assume it will be fine but am not sure given the difference in impedance ratings.
I don't want to spend £200 on an amp that I will have to upgrade due to lack of power, or even worse, risk blowing my speakers as a result of lack of control from the amp. I also don't want to buy an amp which isn't going to get the best from my speakers... Any advice would be very gratefully received.
Thanks all in advance!
__________________
Hi-Fi: Cambridge Audio 740A -> SHB Quintessence -> Cambridge Audio 740C -> QED Silver Anniversary XT Bi-wire -> Dali Suite 2.8 Floorstanders
A/V: Pioneer BDP-430 -> Chord Active HDMI, Sky+HD 1TB -> Chord Supershield HDMI
Other: Western Digital MBWE 2TB NAS, Tacima CS929 Mains Conditioner
grdunn123
grdunn123's picture
Re: Will Pioneer VSX-920 give enough oomph to power Dali Suite 2
They are a difficult load to drive at 4 ohms...might be worth looking at something with a little more 'ooommph'
__________________
Samsung UE55F6510 LED TV, Pioneer SC-LX82, Panasonic DMP-BDT310, Monitor Audio RS5 fronts, GSLCR centre. RXFX rears, Sky HD 1TB, Chord + QED cabling throughout,Xbox 360,Iomega NAS,Apple Ipad 3,Samsung Galaxy S4, Ipod Touch 4th Gen, Samsung Galaxy Tab 2.
dougolada
dougolada's picture
I had thought the same, although I would be using 4 of the 7.1 channels for the front left and right speakers which would help, and I can't imagine the load on the rear speakers would be too much for the Pioneer to handle, at least I would hope not...
The price is the big thing that is drawing me in and I think I will find that more oomph comes at a far greater price tag...
__________________
dougolada
dougolada's picture
Here's the point where I realise that the price of £299.95 "includes £100 voucher from Pioneer", ahh ******! Still a good price but not the £200 amp I had thought it was... Oh well, never mind...
__________________
Ronald Archiebald
Ronald Archiebald's picture
dougolada:
Your speakers will definitely benefit more from better quality amplification.
There are excellent deals to be had in the used-market for higher-end amps.
grdunn123
grdunn123's picture
Agree totally with Ronald.Yes
__________________
dougolada
dougolada's picture
What would you suggest would be a suitable amp to get the best from my speakers?
__________________
Ronald Archiebald
dougolada:
It all depends on the sound that you prefer. But something along the likes of at least a Denon AVR-2310, Onkyo TX-SR805/806/875 should suffice.
dougolada
dougolada's picture
The Denon looks very similar to the Pioneer in terms of specs. Would you say it offers more than the Pioneer than simply what is on the spec sheet?
__________________
David@FrankHarvey
David@FrankHarvey's picture
Personally, I'd look at a used Yamaha DSPZ7 to get the best from them.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
dougolada
dougolada's picture
The Yamaha is less powerful at 140W at 8 ohms, than the originally mentioned Pioneer. Does this mean that you think the Pioneer would be powerful enough for the Dalis?
__________________
grdunn123
grdunn123's picture
Hi, don't go too much on manufacturers quoted power outputs. Something like the Yamaha mentioned above will have vast reserves of current to drive a hard load like the Dalis
__________________
markjaspi
markjaspi's picture
grdunn123:
I totally agree, I had a 920, quoted at 140w @ 8ohms, I now have a yamaha RXV1067 rated at 105w @ 8ohms, and I can tell you for certain the yamaha is much more powerful than my previous pioneer. I think manufacturers measure their outputs in a manner that suits them best.
__________________
Panasonic 50GT30B | Marantz SR5006 | Boston Acoustics A26 front - A225C - A26 rear | Panasonic BDT310 | Sky+ 1TB HD | Virgin TiVo | iPad 2 | Samsung Galaxy SIII | New Apple TV | Control: Roomie via iPad & iPhone | Xbox360
dougolada
dougolada's picture
Do the manufacturers do this to deliberately confuse people??? How is someone with large, hard to drive speakers supposed to match them with an amp when the specs that are stated by the manufacturer would appear to be worthless???
__________________
kevinJ
kevinJ's picture
Look at the amount of power that the amp draws from the socket to get an idea of the output power of the amp.
Since an amp only has an efficiency of 50% (80-90% for digital amps), a 120watts/channel amp would need a 1200watt powersupply when used in 5.1. And that comes with a nice pricetag.
Most of the claimed powerratings are measured using a "downhill, wind in the back and full throttle" method. Mostly they measure the poweroutput when only one channel is driven. That way, 120watts is easy to get. If you're lucky it was measured in stereo mode. I only know two brands that measure poweroutput when 5 channels are driven: Harman Kardon and NAD. And Nad powersupplies aren't the best because they only get the same wattage at 8 and 4 ohms (power should double everytime the impedance is devided by 2). And most home cinema amps have a built in security circuit that limits the power when 4ohm speakers are connected.
So forget about the powerspecs a manufacturer states. Search for an amp with a hefty powersupply and try to get a home demo. That's the only way to make sure it can drive your speakers.
dougolada
dougolada's picture
Thanks Kevin, that makes a lot of sense Smile
Looking back at the amp spec sheets that initially looked very similar in terms of power output, I am now seeing the difference in terms of power consumption and it all becomes very clear...
Pioneer VSX-920 power consumption: 245W  power output 140WPC at 6 ohms
Denon AVR-2311 power consumption: 600W   power output 135WPC at 6 ohms
Initially I assumed that the Pioneer would pip the Denon for power with an extra 5WPC but the power consumption of the amps tells a very different story!
Thanks again for the advice, it all makes a lot more sense now Smile
__________________
