Will a DAC make much difference?
4 replies [Last post]
markhooper32
markhooper32's picture
Hi all , am currently using a sony bdp-370 blu ray player with an onkyo nr609 receiver. Will I find much improvement using a seperate DAC when listening to cd's? I've been thinking about doing this for a while now,the player is connected directly via hdmi cable. - Thanks in advance
__________________
Cool
Chewy
Chewy's picture
RE: Will a DAC make much difference?
If the new DAC is of a higher quality than the DAC in either your BDP-370 or the 609 (which may mean afairly substantial investment), then in theory yes, but any increase in sound quality may be limited by the Onkyo's amplification ability or indeed your speakers.
A wiser investment may be using your budget to upgrade the reciever and/or speakers - this may give you bigger gains in sound quality.
__________________
JVC X70 | Beamax 105" M-Tensioned Screen | PMC MB2i Fronts & MK SS150 Surrounds (7.1) | Paradigm Signature Sub 1 | Primare SP32 | 3 x AB Systems 11000SE Monobloc amps + 6500SE 6-Channel amp | Oppo BDP-95 | UnRaid 16TB Media Server | Netgear NeoTV 550 | PS3 | Darbee DVP5000 | Sonos Multi-room system
markhooper32
I see thank-you for your reply! So how do I find out if the DAC in the blu ray player is better or not than the one in the onkyo because if my thinking is correct and the blu ray player was connected via phono leads then the onkyos DAC wouldnt be used?
__________________
Cool
Chewy
Chewy's picture
Correct. The only way to test is to listen to both configurations, and compare the differences, and yes, if you connect the blu-ray to the amp with phono cables, you will use the players DAC, with HDMI or digital connections you 'should' be using the amps DAC.
Testing is the only way to see if a new external DAC might improve things too - get a home demo and hook it up to find out if you can hear an improvement.
__________________
markhooper32
Thanks chewy  Smile
__________________
Cool
