4 posts / 0 new
Last post
JP007's picture
Last seen: 3 years 2 months ago
Which one?
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Arial","sans-serif"; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;}
It looks like I will be buying this soon: http://www.lg.com/hk_en/home-theater-systems/lg-BH4030S
What I would like to know is if the speaker cables are not long enough, what cable should I buy? There are many here on Amazon, but I do not know which is the best for the LG BH4030S.
http://www.amazon.co.uk/s/ref=nb_sb_ss_c_0_12?url=search-alias%3Delectronics&field-keywords=speaker%20cable&sprefix=speaker+cabl%2Caps%2C233
Thanks!
RobinKidderminster's picture
Last seen: 1 month 2 weeks ago
RE: Which one?
I expect this unit will use simple two wire/figure of 8 cable available at yr local diy store. Just find something of similar wire 'diameter'.
The specs say spring clips so go for slightly thicker if u have long runs and use a continuous length rather than joining cables if possible. Job done
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
JP007's picture
RE: Which one?
Ok thank you. What is the wire diameter for this system? I cant see is says it in the specs.
RE: Which one?
This would be ideal
http://www.diy.com/nav/fix/electrical/electrical-cable/speaker_cable/SLX-Gold-OFC-Speaker-Cable-2-x-79-Strand-20m-9686718
But any electrical store would.have similar. Or ebay/amazon etc
Log in to post comments
