17 posts / 0 new
Last post
nugget2014's picture
Last seen: 1 day 5 hours ago
Where can I find someone with a bk monolith sub to demo?
Fixed on the mono but want to see if in the flesh before buying one. Which site would I find an owner of one (in the Nottingham area) as I don't know if any sites have section in that regard. I don't wanna buy it then find out I don't like it.
Setup: Samsung UE55JS8500, Samsung UBD-K8500 4K Player, Dali Zensor 3, Dali Vokal Centre, Denon AVR-X2200W, Arendal Sub 1, Monitor Audio Radius 45 Samsung S7 Edge
bigboss's picture
Last seen: 1 week 20 hours ago
BK lets you demo the sub for
BK lets you demo the sub for upto 35 days at home as far as I'm aware. Check with them (they're closed until 4th August).
bigboss wrote:
But return shipping at about £30-40 if I didn't want it is a bit of a high price for a demo I think
bigboss's picture
Well, it is about 43kg.
Well, it is about 43kg. Personally, I won't mind paying return postage as I'm more likely to keep it than return.
bigboss wrote:
i think i'd just end up buying it blind and keeping it anyway..would you say its a good sub for a living room sized 14ft by 13ft or i should i get the dali ikon sub mk2? im leaning towards the dali because of the look of it and the design with its own feet and plinth
bigboss's picture
If you prefer Dali's looks,
If you prefer Dali's looks, demo it (should be easy to demo as compared to BK). If you like it, buy it. If you don't, get the BK on home demo.
bigboss's picture
For the budget of your Dali,
For the budget of your Dali, check this one:
http://www.savi-store.co.uk/product/velodyne-spl-800i-subwoofer-spl-800i?gclid=CKfaxL3J478CFeTItAodpBUAhQ
This will be far superior and 4 times more powerful.
CnoEvil's picture
Last seen: 5 days 9 hours ago
Brilliant little Sub.
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
1000w RMS :o 2000w peak :oo
1000w RMS :o 2000w peak :oo but only 8" driver? :/
bigboss's picture
nugget2014 wrote:
Yes, Velodyne are subwoofer specialists who have somehow managed to achieve big bass in compact units. And they're very successful.
bigboss wrote:
£399 for the ikon sub mk2 on movie rooms used but mint condition. worth a buy? im 99% tempted at that price!! http://www.themovierooms.co.uk/dali-ikon-sub-mk2-used-subwoofer.html
the only problem i can think
the only problem i can think of getting the dali is how much LFE content will i be missing by going down to the 26hz on a dali compared to the 15hz on the monolith?
Took the leap and bought the
Took the leap and bought the ikon sub mk2 for £399 including free post and packaging! Combined about £100 cheaper than he monolith and I got the sub I wanted. Can't wait till it come next week I hope Wink
bigboss's picture
(No subject)
Dirol
bigboss wrote: ?
bigboss wrote:
Dirol
bigboss's picture
It means cool!
It means cool! Dirol
Pages
Log in to post comments
