13 posts / 0 new
Last post
nugget2014's picture
Last seen: 3 days 15 hours ago
What exactly does a centre speaker do?
when it comes to centre speakers i had the impression that it is mainly for vocals and the film soundtrack, is this mainly it or does it do more stuff too?
for example, good action scene going on in man of steel would any of the movie bass go to the centre speaker or would it only go to my dali zensor 3's?
Setup: Samsung UE55JS8500, Samsung UBD-K8500 4K Player, Dali Zensor 3, Dali Vokal Centre, Denon AVR-X2200W, Arendal Sub 1, Monitor Audio Radius 45, Elac Debut Atmos
The_Lhc's picture
Last seen: 3 months 1 week ago
RE: What exactly does a centre speaker do?
The centre speaker carries typically 60% of a soundtrack and it'll receive as much bass as any other speaker (which will depend largely on your bass management settings).
Hi-FiOutlaw's picture
Last seen: 1 week 2 days ago
It is one of the most important channel.
http://en.wikipedia.org/wiki/Center_channel
Rega RP6/Goldring Elite MC>Clearaudio Basic Plus
Synology NAS>Auralic Vega>Pathos Classic One MKIII>Dynaudio X12
http://www.the-home-cinema-guide.com/home-theatre-surround-sound-systems.html#axzz32x58fYUx
http://www.audioholics.com/diy-audio/improve-center-channel-performance
davidf's picture
Last seen: 13 hours 40 min ago
It is THE most important channel. This anchors the information from what is happeneing on screen to the screen, so that things sound natural to those not sitting in the sweet spot. Having a centre channel also allows you to change the volume of the centre channel in relation to everything else.
As the_Lhc has mentioned, it carries the majority of the information you're hearing, and in my opinion can account for up to about 80% or more of what you hear, depending on the type of film you're watching.
the little audio company, birmingham
audioquest / audio technica / amphion / bluesound / chord co / cornered audio / elipson / golden ear / innuos / jbl / kef / moon / ophidian / primare / revel / svs
duaplex's picture
Last seen: 4 months 2 weeks ago
The placement of this speaker is also very important.  Are you asking because you dont really hear the benefits of having one?  To put this into context, for HiFi it is non-essential, for AV it is essential.
RobinKidderminster's picture
Last seen: 2 months 3 weeks ago
So few centres match half decent floorstanders. I recon the size, scale & price should be the equal of the fronts. I guess its because a large front would be difficult to integrate into the home environment but purely from an acoustic viewpoint ??
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
The_Lhc's picture
Have you seen the size of some recent centre speakers? They're absolutely enormous.
@lhc. Nope  :oops:
The_Lhc's picture
@lhc. Nope  :oops:
Have a look at the KEF R200 and 600 (particularly the 600). Idiotically big.
NATTY290's picture
Last seen: 2 years 1 week ago
Yes R600C is huge and I had to have TV unit made to fit it in, but it sounds soooooo good :grin:
Lounge: Samsung UE55ES8000, Sky +, Sammsung BDh6500, Elipson Planet L 5.1 Anthem MRX700, SVS PB2000
Kitchen: Elipson Mc1, Elipson Planet L
Den: Samsung UE55ES8000, Sky +, Elipson MC1, Kef R900, SVS PC12-NSD.
Bed Elipson Planet LW
duaplex's picture
Those types of speaker are better suited to dedicated rooms with a transparent screen that can hide it.  Imagine it in a living room!
Glacialpath's picture
Last seen: 6 months 4 days ago
That's not entirely true. All major stereo sound FX will only be in the L & R channels and not through the centre. At times only Dialogue will be put in the center speaker. If they put the same amount of bass through the center speaker as they do the fronts or surround all the dialouge would be too boomy and masked by all the other audio. This would negate the reason for having a center channel.
The main purpouse of the centre speaker is to give better clarity to the dialogue. and other certrally placed audio that doesn't really need a stereo image like foot steps and other foley. Granted to help with room effect or the location the dialogue is being spoken in and if on set audio has been used then there will be more audio in the center including ambiant sound with a slightly deleyed stereo image of the ambiant sound in the fronts to give it the real feel.
I'm sure you know what and M&E track is. These have all the music and effects with no dialoge in and are mostly delivered with the 5.1 soundtrack for forign language versions of the feature the same L+R channels as already in the original language 5.1 mix. Then the forign language dialogue will have it's own room/evironment accoustic effect applied to it if they have bothered to mix it porperly.
There will be instances when the center channle is empty and if a piece of dialogue is panned left or right (most film leave all dialogue in the center unless it's off screen) depending where the actor is on or of screen L/R and none of that dialogue will be in the center channel.
All LFE should go to the subwoofer. Of course you want a good sized center speaker because none of the frequencies for the center channel should ever go to the subwoofer unless it's for effect. So if you want to hear the full detail of any voice be it from a movie or concert then you deffinitely need a center speaker.
Hi-Fi: Campridge audio D500 SE, DACMagic 1, C500, P500.. Monitor Audio BR1 speakers.
H-T: Pioneer; Kuro LX5090, BDP LX71, SC LX73. CA P500. SKY+HD. Rel Q50. Mordaunt Short Avant.
Log in to post comments
