What cables for a Primare BD32?
14 replies [Last post]
iainl2005's picture
Recently purchased Primare BD32 and SPA23, looking to use the multichannel analogue outputs instead of HDMI for the audio.
The question is... How much should I have to spend on the interconnects to get the best out of the system... obviously the dealer recommends a brand of cable he thinks sounds best, but spending £800 on 4 pairs of JPS Lab cables seems a tad expensive.
Realistically how much should I spend and are there any makes I should consider first?
Thanks in advance.
__________________
JVC DLA-X3 | Primare SPA23 | Primare BD32 | Spectral 1552 cabinet | PS3 | XBOX 360 Elite | Wii | B&W 803s Fronts | B&W HTM3s Centre | B&W 805s Rears | B&W PV1 Sub.
cheeseboy's picture
RE: What cables for a Primare BD32?
why would you want to use the multichannel analgue outs over hdmi?  hdmi would give you a perfect signal whereas the multichannels are open to degredation.
So, if you want the best sound quality just use the hdmi....
iainl2005's picture
Apparently the Primare has audiophile DACs and capacitors... don’t get me wrong the sound through HDMI is great, I just want to hear it through analogue to make my decision.
__________________
cheeseboy's picture
in that case I'd have a word with the dealer who was trying to sell you 800 quids worth of cables and ask to borrow them.  If he says no, then you know he's full of (insert rude word here).
To be honest, imho, some normal phono to phono cables should give you a rough idea of if the output will be any better from the analogue outputs, then if you like that, you can see about getting some more expensive ones...
iainl2005's picture
Thanks Cheeseboy
I was going to purchase some Atlas interconnects, 5 stars from What HiFi and only £37 a pair, they should give me an idea of what to expect.
__________________
cheeseboy's picture
was just thinking actually.  Do you have an interconnect you already use that you just test with.  Just go analogue from the player to the amp and listen to a cd, then do the same with the hdmi.  Should give you an instant idea about the differences between the dacs in the two units...
When I set up this combination we use the 2ch XLR out from the BD32 for CD and HDMI for the rest. For clients looking for mulitchannel audio we then also connect up the analogue outs. The sound from the BD32 is superior on 2ch but for movies I would send the signal on. As mentioned above I would look to  try them out and see what you prefer. Everyone has a recommendation but it is what works best for you.
It is a great pairing and one that really nails it for music as well as home cinema. It would be a good test against the Arcam AVR750
__________________
Nick
The Home Cinema Centre
MUSICRAFT's picture
Hi iainl2005I'll recommend
Hi iainl2005
I'll recommend that you should also look at using basic interconnects. Fwiw, as i write this the system i've got a system playing in the background which is connected using basic cables -
Yamaha CD-S300 > basic interconnect (yellow coloured plug ends supplied with a Blu Ray player) used a coax digital > Naim DAC > basic interconnects (supplied with a Trio M-50 Midi system - purchased in 1986) > Plinius Hiato
All the best
Rick @ Musicraft
__________________
Musicraft (Derby), Specialist Hi-Fi/AV & Multimedia Dealer
good accurate audio monitoring and good sound reproduction to all
BenLaw's picture
RE: Hi iainl2005I'll recommend
If you want to use some XLRs to set it up as Nick has suggested then may I suggest these:
http://www.ebay.co.uk/itm/Pair-3M-Blue-Proel-Livewire-Male-to-Female-XLR...
I use (a shorter version) of these between my primare cd31, pre30 and a33.2. They sound the same as the much more expensive XLRs I had before that.
__________________
HiFi   /   A/V   /   Bedroom
iainl2005's picture
Thanks Nick
Unfortunately the SPA23 doesnt have balanced XLR inputs... found that out last week.
I am very happy with the sound through HDMi, though reading through some articles online it is recommended to get the best sound you should go down the analogue route, I do know this is a matter of taste however. What level of analogue do you use when demoing the BD32?
It was a close call between the Primare and the AVR750, having lived with the AVR600 and BDP100 for a few years I just fancied something different, and its great being able to watch a film, skip chapters and pause, without having to constantly play with lipsync which was a major bugbear.
__________________
iainl2005's picture
Hi Rick,
Thanks for your feedback, when you say basic cable, how basic do you mean?
I was going to purchase Atlas interconnects at around £40 a pair.
Iain
__________________
That will be me confusing the receiver and the processor - Doh!
I would still use the analogue output - just RCA this time. CD playback is superior in the BD32 for sure rather than sending a signal via coax or HDMI. It is slight rather than night and day difference but to my ears the better option. I generally use the Audioquest King Cobra on this set - £215/pr as a starting point - but advise you try first as the cable debate rages on and on.
I prefer the Primare sound to Arcam but they are both very good - I can see why you would like the change.
__________________
Nick
MUSICRAFT's picture
iainl2005 wrote:
Hi Rick,
Iain
Hi Iain
Your welcome.
Like ones with white and red coloured plug ends which are supplied with some DVD/Blu Ray players. If you haven't got any then you should also be able buy some at your local electrical store or local market for very little money.
I find that basic/standard cables enable components and systems to breathe. Keep it simple.
All the best
Rick @ Musicraft
__________________
BenLaw's picture
Like Rick, I use standard, basic RCA interconnects (between my onkyo pre/pro and my primare a30.5). IIRC correctly three of these are the red, white and yellow ones you used to get with TVs. State of the art  Smile
__________________
chudleighpaul's picture
Go to a professional audio store and use what the pros use. They will probably make up a set to your exact measurements at a fraction of the price that the HI FI stealers charge.
