6 posts / 0 new
Last post
dirtydean's picture
Last seen: 2 months 4 weeks ago
Weston Digital external hard drive to my Denon 3311
1st question, when I connect my WD HD to my amp it will not recognise it, could this be because of the WD software loaded on it? 2nd question, if so could I change the software? 3rd question, could I make my WD HD into a NAS? while surfing the web a while ago I thought I seen a product that you plunged the usb from the HD and into, and then a Ethernet into a router thus making it a NAS had anybody got any idea what this was? Your help would be appreciated. Dean
True Blue's picture
Last seen: 2 years 3 months ago
Re: Weston Digital external hard drive to my Denon 3311
I think its probably formatted in NTFS and the Denon will only read Fat32 (probably)
You would need to reformat the drive
You mean something like this
Naim unitiserve with Teddy Pardo PSU feeding NDX into Supercapped Nac 282 / 200
Rega P7 with exact feeding into Naim stagleine for vinyl duties
All mounted on Quadraspire Evo racks / dedicated wiring CCT and played through PMC GB1is
dirtydean's picture
True Blue:
Thanks true blue, how do I reformat to fat32? I use windows xp but my little girl has Windows 7.
I was just reading reviews on the usb NAS adapter seems to be ok dose anyone use one of these?
micks_address's picture
Last seen: 2 years 9 months ago
to format it look for a utility on the web called fatformat32.exe you run it from the command line and it will allow to you format any size partition as fat32.. windows will only let you create up to a 32gb partition as fat32..
dirtydean's picture
micks_address: to format it look for a utility on the web called fatformat32.exe you run it from the command line and it will allow to you format any size partition as fat32.. windows will only let you create up to a 32gb partition as fat32..
Thanks sorted it now. I found a program on the internet and it let me format it no problem and only took a couple of seconds.
Thanks all.
Dean
Red Dragon's picture
Last seen: 8 months 2 weeks ago
dirtydean:
True Blue:
Thanks true blue, how do I reformat to fat32? I use windows xp but my little girl has Windows 7. I was just reading reviews on the usb NAS adapter seems to be ok dose anyone use one of these?
In relation to that USB NAS adapter you mention True Blue, could that be used to connect an Iomega media player to my hard drive storage unit while also allowing the HDD to remain connected to the PC ? This would help me out alot as I'm constantly disconnecting/reconnecting the HDD to the player to access my films etc and HDD unit has only one USB port !!
Log in to post comments
