TV cabinet
18 replies [Last post]
duaplex
duaplex's picture
Hi Guys,
I am constantly smashing my head against a wall here. I have a 150cm space to work with and need a new AV cabinet to fit all my equipment into.I have looked at BDI, Salamander and even had a quote from Blok.  The only problem is the AV cabinet is 74cm tall and my TV will sit ontop of it. I know I can go with HiFi Racks, but my goal is to hide the jungle of wires out of sight, so that rules out rack systems.Do you think the TV will be too high at 74cm? is there an option I am not seeing? Everything I have looked at that will accomodate my equipment is too wide or too tall. Do I have to accept life and buy a rack system again?
__________________
Panasonic 65" 3D TV (P65VT50), Pioneer LX83, CA, Azur 751BD, PS3, Water Cooled Xbox 360 (Modded), Nintendo Wii U, Sky HD+, i7 PC overclocked with 6850 HD Radeon, CM8 Fronts (Bi-Amped), CMC Center (Bi-Wired), DS3 Dipoles, PV1 Sub. Van Den Hul M.C. Snowtrack >Halogen Free< wiring, Chord Active Silver HDMI's, Cabridge Audio AUD700 Analogues Interconnects, QED Signature Subwoofer cables, Chunky Monkey custom oak AV cabinet.
BenLaw
BenLaw's picture
RE: TV cabinet
Get a custom rack from the likes of stump furniture or chunky munky.
__________________
HiFi   /   A/V   /   Bedroom
Timbot
Timbot's picture
RE: TV cabinet
Would an Alphason Finewoods 1350 be big enough for all your kit? Or is everything in your signature in the one place?
duaplex
duaplex's picture
RE: TV cabinet
Thank you guys, so I am gathering from the responses so far that I should get a rack instead of cabinet. So much for hiding wires :(Timbot - Everything is in one place. The fine woods are good, but they lack the depth needed for the LX83 which is 46cm deep and with Banana plugs it gets to about 52cm deep. The fine woods have back panels to them, not sure if they can be fully removed?  Will have another look.
I like chunky Monkey by the way!
__________________
gel
gel's picture
RE: TV cabinet
I have an Optimum AV300 customised stand.  Smile
__________________
Panasonic 50GT50, Pioneer Bdp-lx71, Pioneer Vsx-lx70, B&W FPM Series & B&W PV1.
BenLaw
BenLaw's picture
RE: TV cabinet
If you look on the chunky monkey and stump furniture threads on av forums some people have used back panels and other have used removable panels at the front at the bottom for access to cables. They'll basically make anything you ask as long as you can work out how to do it. However, using a custom rack you can have everything fitting so well that you can't see the cables, check the link to my av kit in my sig.
__________________
richardw42
richardw42's picture
RE: TV cabinet
I've just ordered one of these
http://www.ebay.co.uk/itm/NEW-SOLID-WOODEN-BENCH-TV-STAND-ENTERTAINMENT-UNIT-RUSTIC-PLANK-PINE-FURNITUR-/121030029731?pt=UK_Home_Garden_LivingRoom_TV_Furniture&hash=item1c2df3b1a3
It's not here yet so can't give a review, but size wise its what I was after. I've got a 21.9 TV, but bought this as I anticipate getting a Panasonic 65" some time soon.
__________________
TV room : Samsung 60" plasma-ATV3, Denon DBP2012UD-Yamaha RXV3067-AVI ADM9RSS,MA RSW12,/Sonos ZP90 via optical, Sky+ HD & Sky Connector, PS3
HiFi : Sonos ZP90 - AVI ADM40
Bedrooms : 2 x Sonos Play 3
Ipad for Sonos & Spotify
duaplex
duaplex's picture
RE: TV cabinet
Richard that is superb! I am going to get a quote off them too. I have so far contact both Chunky monkey and strump!
__________________
duaplex
duaplex's picture
RE: TV cabinet
Already ahead of you Ben, I took a look earlier, nice setup! How much did they charge you for something like that.
__________________
Timbot
Timbot's picture
RE: TV cabinet
The Finewoods come "flat packed" for assembly. It is possible to just leave the back pannel off or even to "DIY" it a bit with a saw / jigsaw. The back pannel has no structural use at all. Perhaps one of the four pre-cut holes could be enlarged a bit for the banana plugs to poke through? Just a thought...
Petherick
Petherick's picture
RE: TV cabinet
Have you considered putting some of the equipment below the TV and some above? So have 2 smaller units, one on (or near) the floor and one wall-mounted.
__________________
scene
scene's picture
RE: TV cabinet
Before I finally decided on the Salamander, I was too spent a long time looking for a wide (180cm in my case) and high (80-90cm) cabinet. The one I very nearly went with was Kuban who do some very nice AV cabinets, and also have a bespoke department. Very friendly when I dealt with them.
__________________
Hi Fi: Arcam A85, DV88 (CD only), Project Debut II, AE Compact-1. AV: Arcam AVR250, DV79, Sony BDP-S760, Monitor Audio Silver 8i, RS-LCR, RXFX, Sonos ZP90, Pioneer KRP500A. 2nd AV: Pioneer SX-SWR2, Dell Zino HD, KEF KHT2005.2 eggs, Sonos ZP90. That Cable HDMI, Chord Crimsons and Sonos ZPS5s everywhere & a spare Yamaha RXV-667!
bigboss
bigboss's picture
RE: TV cabinet
If you're prepared for a DIY approach, check:
www.ikeahackers.net
__________________
scene
scene's picture
RE: TV cabinet
bigboss wrote:
If you're prepared for a DIY approach, check: www.ikeahackers.net
I did wonder if a hacked Besta-based solution might work - but besta cabinets are 40cm, and the sc-lx83 is 46cm, without cables plugged in...
__________________
Big Chris
Big Chris's picture
RE: TV cabinet
.....Which is the self-same headache I had when it came to housing my Onkyo.banging head against wall
Ikea's 'Tobo' to the rescue. Leave out the two drawers in the centre and there's acres of space for even the deepest of A/V receivers. I cut the panel out on the back to connect all the cables, the Onkyo pushes right back so you see no cabling.Cool
__________________
Hi-Fi: Arcam A85, P85, CD192. B&W 602S3, PV1, Grado SR125, Atlas Titan, Hyper 2.0.
A/V: Sony KDL-V40A12U, BDP-S760, Humax Youview, Onkyo TX-SR875, B&W MT30 7.1, QED HDMI-P, S.A XT
scene
scene's picture
RE: TV cabinet
Ooh! nice one!
(I love when you search for it on the Ikea website, how it comes up in the 'For tube TVs larger than 25"' category rolling on the floor laughing )
__________________
