7 posts / 0 new
Last post
kingnothing83's picture
Last seen: 1 year 9 months ago
To bung or not to bung
I've been talking on another thread and my new CM5 purchase. That's made me think about placement and as the speakers just have to go less than 0.5m away from the wall and one speaker is relatively close to a sidewall then I'll try using the supplied bungs if bass is too boomy
but this made me think generally about my rear setup. I have my b&w 686 as rears, wall mounted. Not best practice I'm sure but the best I can do in my living room. They're a nightmare to move so I'd rather not but I've just realised I forgot to put in the bungs, they'd probably help as they're rear port and wall mounted. But is it worth the hassle of taking them down? I've got the speakers set up as 'small' with a 80hz crossover, so surely the bass isn't being heavily used anyway on the rears?
is it likely to make a big difference to bung the rear 686's or should I just forget about it? Smile
RobinKidderminster's picture
Last seen: 1 month 2 weeks ago
RE: To bung or not to bung
I should not worry. Unlikely to make a difference. Mine are rear ported and have tried bungs.
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
Did you not hear a difference
Did you not hear a difference with or without bungs? Guess I could always try upping crossover to 100hz for rears too
mr malarky's picture
Last seen: 2 years 6 months ago
Your rear speakers will be doing very little base-wise (partly because if your settings, and partly because of how sound is typically distributed between channels in a surround mix), so I wouldn't worry.  Smile
Good stuff
Good stuff Smile
davidf's picture
Last seen: 23 hours 27 min ago
Easiest thing to try is to
Easiest thing to try is to put on some music with decent bass using 'all channel stereo' mode (if you have it). You could disconnect the front and centre speaker and turn the sub off so you can't hear them, so you're just left with the surrounds running. Then try the bungs in and out and see what you think. Even though the port will be tuned to a lower frequency than the crossover point you're using, chances are you will still hear a difference, as it will still have an effect on how the speaker sounds overall. Then just choose your preference.
Do try a few different tracks though, as 'bassy music' can sometimes be centred around a small bass frequency range, and show up less of a difference.
The Little Audio Company
audioquest / audio technica / bluesound / chord co / cornered audio / golden ear / harman / innuos / jbl / kef / moon / ophidian / primare / revel / svs
jjbomber's picture
Last seen: 1 week 1 day ago
Saw the headline and thought it was about the iphone 5s winning an award!!!
Log in to post comments
