3 posts / 0 new
Last post
powerman's picture
Last seen: 2 years 6 months ago
Tannoy sub settings
Hello.
I have just bought the Tannoy SFX Sub,and was wondering what the correct position for the active phase switch is . Theres two options 0 or 180
Thank you
michael hoy's picture
Last seen: 11 months 1 week ago
Depending on the distances of
Depending on the distances of the subwoofer and the main speakers from the listening position, the bass in the crossover region may be smoother if you reverse the subwoofer’s phase. Typically, though, phase is left at 0° for most applications.
While seated in your listening sweet spot, play music with bass content that is familiar to you and then have someone switch the 0/180 phase switch on the sub to 180-degrees. This will let you determine if the bass sounds louder in your seating position. The more bass-heavy setting is where the output of the subwoofer and the main speakers are most in phase. Use whatever position (0/180) is louder at your seating location. (Note: some subwoofers may contain a “variable” phase control, which provides variable control between 0 and 180 for even more precise phase control of your subwoofer.) However, if you do not notice any difference when changing the 0-180 setting, it only means there are no issues in your room and all is fine.
AV- Panasonic VT30¦Pioneer LX85¦MA Apex Speakers¦Antimode 8033S¦OPPO 95 BDP
Hi-Fi- Spendor A3¦Cyrus 8 XPD QX¦Quad 909 power amp
Music stored on Server running Windows Home Server.
powerman's picture
Thank you. I will have a play
Thank you. I will have a play tomorrow
Thanks again
Log in to post comments
