6 posts / 0 new
Last post
mikey2008's picture
Last seen: 3 years 2 months ago
Tannoy HTS-101 and Yamaha RVX-673
Hi all,
I'd like to audition the above Tannoy speakers but am a little unsure which might be the best AV receiver to match with it. I'm thinking about the Yamaha RVX-673, but from what I've read, together the sound might be a bit warm when coupled together. The alternatives in terms of the amps could be a Onkyo, Pioneer or Sony which are potentially a better match. Any initial advice to narrow down the choices would be much appreciated.
Many thanks,
Mike
f1only's picture
Last seen: 5 days 10 min ago
RE: Tannoy HTS-101 and Yamaha RVX-673
Tannoy F series with Pioneer go quite well together having owned both in the past together. I sold the whole system to a friend who got some DC4 tannoys as Front L/R as a replacement speakers about a year later & it sounds even better now. Laughing
Regards ...
A/V Pioneer SCLX59 Speakers B&W 683 S2 685 S2 HTM61 S2 Centre 686 S2 For Atmos x4 ASW610 Sub x2 TV Calibrated 4K Panasonic TX-50AX802B BDP Sony PS3 & PS4 Pro HDMI Monster ISF2000HD Virgin Tivo Netgear ReadyNas104 12TB
mikey2008's picture
Thanks for the reply f1only. I haven't seen too many great reviews of budget range Pioneer AV amps. Are there any out there which you'd recommend for an audition?
Thanks,
mike
f1only's picture
Budget range you could audition the Vsx922 Clicky there are some good bargains to be had if you are willing to shop about depending on where you live.
mikey2008's picture
Cheers mate. I'll give it an audition, although reviews aren't the greatest.
f1only's picture
You can always look at last years offerings at knock down prices. For example some of the Yamaha AVENTAGE range, the 1010 & the 810 can be had for good money all depending on your budget of course.
Log in to post comments
