11 posts / 0 new
Last post
toyota man's picture
Last seen: 3 months 2 hours ago
Support for Center speaker Required HelpPlease
Hi All Ive just got a new center speaker and it sits on top of my equipment rack I need some kind of support so the tweeter isn't firing sound ar my knees I have seen some posted on hear that are wedge shaped but after searching I have almost lost the will to live so if you could help I would be very gratefull Smile
Musical Fidelity M6500i, Musical Fidelity M6 CDP, Musical Fidelity Encore Connect, ATC SCM 40s, Cord Chameleon plus XLRs, Tellurium Q Black speaker cables.
Glacialpath's picture
Last seen: 6 months 3 days ago
RE: Support for Center speaker Required HelpPlease
You could just cut or get someone to cut and give a nice finish to a piece of wedge shaped wood.
Is your screen on a stand or wall mounted? If it's wall mounted can you not put a shelf under you screen to make it a little higher and then you could incorperate a wedge shape to point it upwards towards you ears.
Mine is on my AV rack and kind of fires at my chest but I'm happy with how it sounds at the mo.
Hi-Fi: Campridge audio D500 SE, DACMagic 1, C500, P500.. Monitor Audio BR1 speakers.
H-T: Pioneer; Kuro LX5090, BDP LX71, SC LX73. CA P500. SKY+HD. Rel Q50. Mordaunt Short Avant.
VoodooDoctor's picture
Last seen: 1 month 1 week ago
Go to Tesco and get some door wedges for £1. Use blutak to fix them on. Job done. :rockout:
Leeps's picture
Last seen: 1 week 1 hour ago
I use Auralex Mopads for my centre speaker.  They come in a pack of medium density foam wedges that you can stack to vary the angle.  They isolate the speaker from my MDF rack pretty well and point the tweeters up so they're facing ear level at the seated position. They're designed chiefly as stands for studio monitors but do the job nicely for my centre speaker.
£35 pretty well spent, although you're welcome to try the less expensive Blue Peter suggestions above first.
Tidal, Cambridge 640CD, Pioneer BDP450 Bluray, Pioneer VSX-2021 AV receiver, Ruark Talisman III, Ruark Dialogue II centre, Ruark Epilogue II rears, MA R370HD sub, Panasonic TX-P42G30B plasma
A somewhat unsightly recommendation don't you think. No doubt they would do the job though.
I have some clear ones that you would hardly notice. I don't use them for this purpose now (I had them on top of my bass traps angling my height speakers downwards). Depends how much money you want to spend I suppose.
Hi voodooDoctor thts a good idea even if its to get the angle required before getting some thing a bit more upmarket thanks for the suggestion :grin:
Hi Leeps I will look into Auralax Mopads after Ive had a play with the door stops  :cheers:
Hi Glacialpath I might look into that the speaker is a gloss piano black
spiny norman's picture
Last seen: 1 week 9 hours ago
These seem good value
And so, on Feb 22nd 1966,...
You're welcome.
Log in to post comments
