Subwoofer Help !
6 replies [Last post]
camac
camac's picture
I am in the need of some advice. I turned on my system this morning and after a while the sub developed a buzzing / humming sound when it was active. The sub is a Moniter Audio RSW12, fed from a Sony STR-DA5400 av receiver. The sub was on auto so it only buzzes / humms when active. When i checked all the connections, everything was fine . When i disconnect the cable from the av receiver to the sub it still buzzes / humms, so it is not the cable or receiver. Any advice guys ? Thanks.
__________________
SmileGaun Yersel.
David@FrankHarvey
David@FrankHarvey's picture
RE: Subwoofer Help !
So the sub hums with only the mains cable plugged into it?
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
camac
camac's picture
Hi David,
Thanks for replying.
Correct, it humms with just the mains cable in. but only when it`s active. If you turn on the sub  but have the switch set to auto or off, no humming, but as soon as you flick the switch to on  it starts humming.
Thanks.
__________________
SmileGaun Yersel.
David@FrankHarvey
Then it's an internal problem and you'll need to get it back to an MA agent to sort it out for you.
__________________
camac
camac's picture
Thanks David.
I am based in Central Scotland, do you know of any in my area or my nearest one ?
Thanks.
__________________
SmileGaun Yersel.
David@FrankHarvey
Not off hand, but there's plenty of dealers about, so there should be one not too far away. Check the Monitor Audio website, as you'll be able to search for a list of local dealers with that Smile
__________________
camac
camac's picture
Hi David,
I have contacted Monitor Audio through their website. I will wait to see what they say about the problem, as the sub is only 2 years old.
Once again Thanks.
__________________
SmileGaun Yersel.
