6 posts / 0 new
Last post
steakers's picture
Last seen: 8 months 5 days ago
sub woofer settings
not sure im posting in the right place , id like to get my settings right on my sub , ive used audessey to set up my speakers , as for the sub what should the phase and crossover be set to , ive set the crossover for all speaker to 90  , does this mean i need to set the sub cross over to 90 aswell . any tips most welcome.
cheers
robinkiddie's picture
Last seen: 2 years 6 months ago
What is your kit? If your amp
What is your kit? If your amp is set to 90hz, set yr sub to max (200+) since the amp deals with crossover and sends no signal above 90. Positioning? Google will recommend the 'crawl' although in practice most of us have limitations on position.
Yamaha V2065. MS 8's, 1,5,9. Panasonic 42. Sony BD. Garrard 86SB. WD live TV. Galaxy 10.1
michael hoy's picture
Last seen: 11 months 2 weeks ago
Would be easier to reply if
Would be easier to reply if we knew the make and model of the sub, do you have the manual for the sub.
AV- Panasonic VT30¦Pioneer LX85¦MA Apex Speakers¦Antimode 8033S¦OPPO 95 BDP
Hi-Fi- Spendor A3¦Cyrus 8 XPD QX¦Quad 909 power amp
Music stored on Server running Windows Home Server.
steakers's picture
sorry the subs part of my
sorry the subs part of my Qacoustics 2000i 5.1 kit  , ive had to position the sub to the side of the settee due to partner limitations , out the way basically but not in a corner .  im using a Denon avr x2000 A/V amp aswell.
steakers wrote:
OK,
You should have the switches etc as per below.
Use the recommended settings below.
Let your amp do all the rest.
steakers's picture
thanks will try later ,
Log in to post comments
