Speakers to mount on side of a chimney e.g. Minx
2 replies [Last post]
AndrewFG
AndrewFG's picture
I have a Tv mounted on a chimney-breast; it covers the full width of the chimney, and there is no place for the speakers beside it. Therefore I am looking for something that can mount on the side of the chimney, rotated to face forward. So in other words I need a wall-mount speaker whose bracket can rotate a full 90 degrees. I am thinking of the Cambridge Audio Minx speakers, but it is not clear from their online installation instructions if the wall mount brackets can swivel this far. Does anyone have these speakers with wall mount brackets who could tell me if this is physically feasible? Or does anyone have alternate ideas?
RobinKidderminster
RobinKidderminster's picture
Online
RE: Speakers to mount on side of a chimney e.g. Minx
Looking at the brackets, if they dont work you could add a 90deg metal bracket or maybe a wooden cheese shaped wedge dependant on decor and diy skills. Else look at off the shelf wall brackets. So small there should be plenty. Or a wooden batten behind the tv using the minx brackets?
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1Base trap Project - http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-pro... treatment - click for pics : Room pix - Clicky : Old setup - Clicky
AndrewFG
AndrewFG's picture
Many thanks for the helpful response.
Nevertheless I am still hoping for something that would not call on my DIY "skills"...
