speaker package for a Yamaha rx A3020
32 replies [Last post]
jcshutts
jcshutts's picture
I am looking for a speaker package at around the £2k bracket that will marry well with the Yamaha RX A3020 Amp and provide some musical delights as well!
ideally I would seek to wall mount the pakage although it might be difficult to find a speaker which provides mid and fullness of sound in a small box which is bracketed to a wall????   If not would settle for floor standing.
Any pointers?
bigboss
bigboss's picture
RE: speaker package for a Yamaha rx A3020
http://www.dougbradyhifi.com/p-108-monitor-audio-apex-av-hi-fi-surround-...
If you buy the AV receiver & speakers together from the same dealer, you may get a discount. I got 10% discount off my speakers & subwoofer from Sevenoaks.
__________________
jcshutts
jcshutts's picture
its very perceptive of you to know that I haven't actually bought the Amp yet!  My Yamaha Z9 packed up this morning so I am planning the exchange and hoping the wife won't notice! Concerned that I might struggle to smuggle in the new speaker package at the same time too though!  Was hoping for a couple of months to recover after Santa robbed my piggy bank again!
Any ideas on the right speaker package? I may be lucky in convincing the wife for a simultaneous purchase if it makes financial sense!!
jcshutts
jcshutts's picture
just followed the link.  Monitor Audio.  Will they sound full enough do you think!
bigboss
bigboss's picture
An emphatic yes!! It was the What Hi Fi award winner for best in class last year.
Have you seen the size of this thread?
http://www.whathifi.com/forum/home-cinema/the-apex-club
It's the biggest on the forum regarding one product, as far as I'm aware.
__________________
David@FrankHarvey
David@FrankHarvey's picture
The mid fullness of a 'satellite' speaker will never match that of a floorstander, but I'd recommend looking at the B&W M1 satellite speakers - either as part of the MT60D package, or with a different subwoofer. The new M1's are much fuller sounding than the older ones, and sound more like small bookshelf speakers, given a good quality receiver to drive them with, which the RXA3020 fully qualifies.
The key to good sounding satellite speakers, other than set up, is a good subwoofer. Stick to a sealed cabinet sub for small satellites, so the PV1D is a good start. If you want something more capable in almost every department, the KK Sound DXD808 would be the best alternative providing deeper bass and better punch, sounding cleaner across the sub's operating range (high or low), and being fast enough to pull off high quality music without drawing attention to itself.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
MUSICRAFT
MUSICRAFT's picture
Hi jcshutts
In addition to Apex sub/sats Monitor Audio's Silver RX6 AV12 speaker system and their Shadow Series of speakers (with Silver RXW-12 or Apex AW-12) are also worth consideration. As with Apex speakers, Silver RX6 AV12 and Shadow speakers also pair superbly with the Aventage RX-A3020 with music or movie soundtracks.
http://www.monitoraudio.co.uk/products/shadow/
All the best
Rick @ Musicraft
__________________
Musicraft (Derby), Specialist Hi-Fi/AV & Multimedia Dealer
good accurate audio monitoring and good sound reproduction to all Smile
jcshutts
jcshutts's picture
Superb thanks . Will do some reading
RickyDeg
RickyDeg's picture
I have to agree with my fellow posters above on the Monitor Audio Apex recommendation. They are a thrill-ride of a package, and far from "just" any old style-system. I know what you mean when you mention the word 'fullness' and I honestly don't feel that aspect is missing in Apex, especially considering their size. With the 'right' kit to drive them they will offer a nicely balanced sound suitable for several types of genres of music and movies. Not just saying this because I own them myself but rather because I've heard many other similar solutions (including Focal Dome, B&W M1, Paradigm Milleniaone etc) and none of those managed to impress to the same extent that Apex continue to done (personal opinion). They do require capable grear do them justice but I'm certain if you dig Yamaha's characteristics then RX-A3020 will be fine (many users pair these two with great sucess).
If you can house a package containing just the bigger Apex A40 then use that all-round, otherwise the 'standard' 5.1 package contains A40 and the smaller A10, which work great together. Naturally I would also recommend the AW12 subwoofer, for more than just aesthetic reasons. Mounting options are fairly flexible - wallmount (A40 + A10),  tabletop (A10) or separate floorstand (A10).
Best of luck whatever you choose! If you land on Apex then please 'join' us in the club!
__________________
>>> VIEW MY SYSTEM THREAD HERE <<< Current equipment: DENON AVR-3808 | OPPO BDP-93 | MONITOR AUDIO APEX 5.2 | SAMSUNG LE-52B755 | YAMAHA CDR-HD1500 | HUMAX BXR-1000 HDTV SATELLITE | ISOTEK EVO3 SIRIUS | NORDOST PULSAR POINTS | LOGITECH HARMONY REMOTE 900
bigboss
bigboss's picture
You can save more than £1000 by going for 3010 instead of 3020 for similar performance.
__________________
Son_of_SJ
Son_of_SJ's picture
Once more, bigboss is right. Unless you want or need fancy new stuff like 4K video passthrough and maybe Spotify (whatever the hell that is) then the Yamaha RX-A3010 will be excellent as a home cinema hub and much cheaper than the new 3020. Reviews here http://www.homecinemachoice.com/news/article/yamaha-rx-a3010-av-receiver... and http://www.whathifi.com/review/yamaha-rx-a3010 . It is now available for just under a grand, half of its launch price, at peter tyson http://www.petertyson.co.uk/ebuttonz/yamaha/avreceivers/index.shtml?goog... and at Creative Audio / Audio Express http://www.audio-express.co.uk/hotdeal.php?&cat=HCAMP&HOTDEAL=YAM_3010&t=ga or Exceptional AV http://www.exceptional-av.co.uk/index.php?search_terms=A3010&gclid=CJnr_.... Rick at Musicraft and David at Frank Harvey will tell you how good it is, especially at what is now truly a bargain price.
Or, you could pay £2,000 for the 3020!
jcshutts
jcshutts's picture
Problem with this hobby is that it is always tempting to buy the products that have all the available options such as the 3020. Is the internals exactly that of the 3010 apart from 4k?
The apex sound like a winner
bigboss
bigboss's picture
All I can say is that there isn't a £1000 difference between the models on performance.
__________________
duaplex
duaplex's picture
Yes then put that extra 1000 into the CM8 package.
These Monitor Audio Apex boys.... Trying to run the world  :)
__________________
Panasonic 65" 3D TV (P65VT50), Pioneer LX83, CA, Azur 751BD, PS3, Water Cooled Xbox 360 (Modded), Nintendo Wii U, Sky HD+, i7 PC overclocked with 6850 HD Radeon, CM8 Fronts (Bi-Amped), CMC Center (Bi-Wired), DS3 Dipoles, PV1 Sub. Van Den Hul M.C. Snowtrack >Halogen Free< wiring, Chord Active Silver HDMI's, Cabridge Audio AUD700 Analogues Interconnects, QED Signature Subwoofer cables, Chunky Monkey custom oak AV cabinet.
jcshutts
jcshutts's picture
Will take a look at the CM8. If I did stick with the 3020 yamaha with 4k video processing would this upscale a standard resolution projector???
having looked at the B&W CM8 they won't suit as I need wall mounts . Thanks
bigboss
bigboss's picture
There is currently no 4K content in the market, for the AV receiver to upscale.
__________________
