sony STR-DA5200ES
1 reply [Last post]
durbin
durbin's picture
I now its an old tv but Im buying the Sony JDL-40W2000 LCD!
After some thought Im like  80% certain to buy the STR-DA5200ES receiver- found a good price of £730 and seeing as its 7.1 surround  though would it go with the speakers below!
Or would I be better off going for its cheaper cousin, the SONY STR-DA1200ES?
I was looking at the B&W MT20 5.1  though Id rather pay the extra and go for the B&W MT30 5.1
My question after Ive decide which speaker set to go for is do I need to purchase a sub? I noticed the B&W PV1 SUBWOOFER got a good review etc though it only comes with the MT30 package.
Are those speaker sets a wise choice to go for?
Ive also noticed B&W VM1 centre/AV speakers which go by the side/underneath the tv!
My last question is do I need these seeing as the speaker sets comes with 5 speakers- although they are smaller?
advise very much appreciated on all the above questions!
Andrew Everard
Andrew Everard's picture
Re: sony STR-DA5200ES
Yes, go for the 5200 over the 1200 - you won't regret it.
The main difference between the MT20 and MT30 packages is that subwoofer - the 30 comes with the PV1, the 20 with the good but not quite so amazing AS2 subwoofer.
You can add extra MT1 speakers to either package to create a 6.1 or 7.1 system.
 If you'd prefer the VM series speakers, you can buy these for the front channels, and combine them wit MT1 rear speakers and PV1 subwoofer. Your local B&W dealer will be able to advise on prices.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
