sky HD cables
1 reply [Last post]
Macmillsy
Macmillsy's picture
Hi
we recently had sky HD installed and have since changed where our box and TV is so we have about 4 feet of sky HD cable from satellite in room which is much more than I need. Can I cut both cables shorter and re-attach the connections which go to the box? Any ideas? should I get Sky to do it or is it dead easy and foolproof?!
Mark
D.J.KRIME
D.J.KRIME's picture
Re: sky HD cables
Yes you can cut off the excess coax then reconect the connectors to the coax and it is not something you need SKY to come and do for you. In my house where the 2 coax feeds come into the house through the wall I have cut the cables and installed a neat wall socket so if ever I decide to move any equipment i simply change the coax from the socket onwards.Geeked
__________________
My usefull posts Laughing How To Calibrate Your TV
