Settings on my Sony S570 Blu-ray Player
8 replies [Last post]
andytucker's picture
Hi there i converted from a Fat PS3 to a Sony S570 but jut checking i have my settings set up correctly to get the best possible sound when play HD Master Audio/HD DTS Blu-Ray Discs. I am running it through my Onkyo 608 Receiver.
On the BD Audio Mix Setting do i set it to Off or On?
DTS Neo 6 Setting do i set it to Off/Cinema or Music?
Audio DRC do i set to Auto/Standard or Widerange?
Thanks in Advance
Andy
EvertonMonkey's picture
Re: Settings on my Sony S570 Blu-ray Player
I think if you are bitstreaming to the Onkyo 608, BD Audio mix should be set of OFF
I assume that the neo setting is for the onboard decoding,
and I'm not sure about the Audio DRC.
__________________
Sony KDL-40W4000 - Yamaha RX-V2067 - KEF 3005SE 5.1 Speakers - Sony BDP-S770 - SKY HD - Asrock Core 100 HT-BD HTPC - What Hifi Subscriber for over 10 years.
Could any of the What hifi testing team confirm what we should be setting the Audio DRC to ?  Auto, stadard or wide range.
__________________
davejberry's picture
I have the similar S350
I suggest you set BD mix to  off, DTS Neo to off as you are using the onkyo to do the decoding. I have audio DRC set to auto.
This should send un-altered signal to your receiver for decoding.
__________________
LOUNGE: SONY KDL-46W4000; STR-DA2400ES & BDP-S350; SKY+; TOSH SD3010 DVD; PIO PD-F1009 MULTI CD; WII; KEF CRESTA 2 fronts,CRESTA 1 rears CRESTA CENTRE; BUDGET INTERCONNECTS & 79/42 STRAND OFC SPEAKER CABLES    BEDROOM: PANA TH42P-WD6;
I've read alot on the web that say it should be set to wide range, just wondered what the test team used when they test these players out.
__________________
Andy Clough's picture
EvertonMonkey:
We'd recommend setting it to standard, but it's worth experimenting to decide which sounds best to you.
__________________
Andy Clough is Editor-in-Chief of What Hi-Fi? Sound and Vision and whathifi.com
Twitter @AndrewClough
Google+ Andy Clough
Andy Clough:
EvertonMonkey:
Hi Andy,  Thanks for the reply.  In the manual standard suggests that it compresses.
__________________
Andy, any further info on why it should be standard and not wide range ?
__________________
RE: Settings on my Sony S570 Blu-ray Player
Sorry. An old thread but can anyone list the correct/best settings.. Thought I was right but now confused.downmix, pcm, dsd ... phew!
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic TX-P42G20B., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
