RXV3067 YAMAHA AMP
I have a yamaha RXV3067 amp, Ive been using both hdmi outputs, but recently hdmi 2 seems to have stopped outputting a signal, I've checked the on screen menu and it shows output selected to both hdmi sockets. I was away when it stopped working and a setting could have accidently been changed on the remote but i cant see anything wrong. I've swapped the wires over to no avail, both connections seem ok as well.
Anyone got any ideas?
thanks in advance
Hi Julian,
thanks for your reply, ive just done that, then went to initialize all then switched amp off, as suggested by rick from music craft i seem to have posted the same post on twice i did one at work and thought it hadnt loaded up so did it again when i got home.
sorry its taken me a couple of days to reply, ive been busy with other things
mull
- Login to post comments
Have you tried powering the Yamaha off ( and at the mains and with the power chord disconnected too ) ? A power reboot can sometimes sort out issues. If not then you might have issues with the hdmi board......
Let us know how you get on......
AV: Oppo 83 Bluray, Yamaha RX V3067 AV, Monitor Audio Apex 5.1, Vortexbox Appliance 2TB, Boxee Box, Apple TV, Panasonic 46" Plasma.
HiFi: Squeezebox Touch, Audiolab M-Dac, Musical Fidelity A3.2cr Power Amplifier, Monitor Audio GX 300
Other: Cowon Z2, Fiio E17 DAC, Audio Engine A5 Speakers, Denon AH-D2000, Denon AH-D5000
