2 posts / 0 new
Last post
vpacalypse's picture
Last seen: 3 months 3 weeks ago
Projector Setup
If you put a projector on the ceiling, to connect it to your amp or blu ray etc....would you need to run a lengthy hdmi cable to achieve this.
Or is there another way, i'm not aware of, thx.
Andrew Everard's picture
Last seen: 3 years 4 months ago
Re: Projector Setup
Yes, you would. There are alternatives using HDMI-to-Ethernet cable converters, but these tend to be more expensive than running HDMI cable for all but the longest runs.
Log in to post comments
