Onkyo unveils LS5200 2.1 home cinema system alongside network stereo and AV receivers
Onkyo says the trio of products are the result of 70 years of “audio design excellence”. Designed as lifestyle components, they support a range of streaming services and can form part of a multi-room system.
The LS5200 is a 2.1-channel home cinema system comprising a slim and compact main unit, satellite speakers and subwoofer. The other two new products are the TX-L20D network stereo receiver and the 5.1-channel TX-L50 network AV receiver, which can be used for music and movies.
All three models have built-in support for AirPlay, Spotify Connect, Google Cast and wi-fi, meaning you’re not short of options when it comes to streaming audio content. Onkyo has also thrown Bluetooth and internet radio support in for good measure and everything can be controlled via a companion control app.
The LS5200 delivers 2 x 85W of amplification to the supplied speakers, with phase-matching technology guaranteeing a "cohesive stereo image”, according to Onkyo. The SKM-648 satellites feature an 8cm cone woofer and a 25mm balanced dome tweeter, while the SKW-B50 wireless sub has a 16cm downward firing cone.
The LS5200 supports HDCP 2.2 through its single HDMI input, which means it can handle 4K Ultra HD signals from streaming boxes and Ultra HD Blu-ray players. DTS-HD Master Audio and Dolby TrueHD soundtracks can be decoded, and Onkyo has included a number of DSP listening modes to alter sound settings.
Inputs include two analogue, one each of digital optical and coaxial, and a moving magnet phono input. A USB Type A port can be found on the front alongside a 3.5mm headphone out.
Finally, FireConnect multi-room technology is onboard to send audio from any source to wireless speakers around the home. Onkyo says some wireless speakers are in the pipeline for a future release.
The LS5200 is due to be released in October, priced £749.
The latest hi-fi, home cinema and tech news, reviews, buying advice and deals, direct to your inbox.
MORE: Q Acoustics M7 review
The TX-L20D network stereo receiver and TX-L50 network AV receiver have similar specifications to the LS5200, but the speakers aren't supplied.
The two models differ in the number of speaker outputs: the L20D is a 2.1-channel system, while the L50 can support a full 5.1 surround-sound system.
The TX-L50 is due out this month, priced £499, while the TX-L20D should be available from October for £449.
Max is Editor of Australian Hi-Fi, What Hi-Fi's sister publication in Australia. It wouldn't be his first exposure to the world of all things hi-fi and home cinema, as his first role in technology journalism was with What Hi-Fi? in the UK. Clearly he pined to return after making the move to Australia and the team have welcomed him back with arms wide open.
