Positioning of surround speakers?
1 reply [Last post]
camdxr
camdxr's picture
Hello ,
I am moving my system into a new room and the only place to fit my 4 x monitor audio silver rsfx is up high, roughly 2.5m high in a room with 2.8m ceilings.  To maintain decent surround sound I was considering angling them at 45 degrees?  Is this necessary?  I am worried that if I don't all of the effects will take place, quite literally above my head.
does anyone else have experience of positioning speakers such ad these so high?  Should the settings be on dipole or bipole in such a location?
many thanks
Cameron.
__________________
Panasonic 65VT50, Pioneer PDP LX508D, Denon AVR4308a, Denon AVR3805, Denon 2500BT, Denon DVD3910, Toshiba XE-1, Humax HD, SKY HD, MA RS8's, MA RSLCR, MA RSFX x 4, MA RSW-12. Tacima, Atlas cables. Harmony One.
legoyoda
legoyoda's picture
RE: Positioning of surround speakers?
I have my rear surrounds up high due to necessity (high and level with the listening position not behind).  They are B&W M1 satalliets.  I found the soundfield improved greatly when the surround speakers were angled to point down and towards the listening position (effects sounded better and more "surround").  In fact the best results were obtained from getting them to point on to the wall the sofa backs on to and then letting the Amps autosetup calibrate based on this (they are probably bouncing off the wall a little so the amp stuck in delays I think).  perfectly happy with the setup I have in less than ideal conditions.  Def sounds better than not angeling them.
