Panasonic DMP-BD35
Thu, Nov 6 2008, 3:33PM
Currently i have a PS3 and a Yamaha RX-V363 Amp. My question is will my amp be able to process True HD if i bought the Panasonic DMP-BD35 Player. Dont get me wrong the PS3 is a fine machine but i would look to get the benefit of True Dolby HD Sound. Do i have to upgrade my amp then.
Your amp will not be able to process the HD audio formats, and since the BD35 has no Multi channel outs, you cannot get HD audio. If you're set on buying the BD 35 player then you will need to upgrade to an amp that can decode the HD audio or alternatively you can upgrade to the BD 55 which has Multi channel outs to connect to your Multi channel inputs on your 363 amp.
