Opinions in this soundbar please
4 replies [Last post]
FunkyMonkey's picture
Just ordered this. Any experiences please? Sounded a different category to every other soundbar up to 500 quid.
Panasonic SC-HTB527EBS
Just cannot find a review.
RE: Opinions in this soundbar please
So had this ten days. It has a warm, rich sound. Surround and stereo effects are not precise, but certainly fill the room.
Overall happy. One problem. The bass is too rich and not controllable.
It's a downfiring sub. I have moved away from corner of room and away from wall which helps. Any other advice how to tame the bass, please?
bigboss's picture
It is indeed strange that the subwoofer cannot be controlled. Have you checked the use manual? Subwoofer placement is the only other option. Check different placements within the room. Also place a thick carpet underneath.
__________________
There's nothing about controlling the bass in the manual. It's a wireless sub so can be place anywhere within a couple of metres from a power socket. I suppose I could put as far away from wall as possible when in use then just place back when not in use.
I think the sub is ported. Try foam bungs. Is the bass consistent around the room or is the seating position a bass reinforcement area? If so the positioning ahouls solve it.or a little room treatment
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic TX-P42G20B., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
