6 posts / 0 new
Last post
AVNoob2014's picture
Last seen: 2 years 6 months ago
Onkyo TX-SR505E and Sony BDP-S790 connection problems
Hi everyone - having a bit of a nightmare with this one.....
I decided to use Sony's dual HDMI out on the player. I came out of HDMI 1 (Video) Port to my Philips TV and out of HDMI 2 (Audio) to the 'HDMI IN 1' at the back of my receiver. I then went to the settings menu on the Player and turned off the option that mixes the audio and video together for a single cable output....
Result is : I have a great picture on my tv but not a sound coming out of the amp - I think I've assigned the HDMI on the amp but its soooo confusing to set up - I'm sure I'm missing something.........any ideas people ??
chrisup's picture
Last seen: 1 day 2 hours ago
I have an Onkyo 905 and a Pansonic DMR BW720 and a Sony 760. You need to look on Page 33 of your manual it says
Audio (HDMI) Auto: Normally select this. Outputs audio signals according to the status of the connected HDMI device.
BD Audio MIX Setting Off: Outputs the primary audio only.Select this to output HD audio signals to an AV amplifier (receiver). Dolby Digital / DTS Bitstream: Select this when connecting an audio device with a built-in Dolby Digital/DTS decoder
I hope this helps
Chris
Onkyo 905 B&W 685 Theatre & B&W ASW 610 subwoofer Panasonic DMR BWT 720
Okay - I'll check it out and
Okay - I'll check it out and let you know.....
Thanks - appreciate the reply
Paul
Hi Chris
Yeah....this is how I had things set up on the player....
Maybe I have something not set right on the amp ? I read somewhere some guy was having similar problems with his Onkyo amp and a Sony 790 - also in dual output mode. He mentioned as the amp wasnt getting any video signal it wouldn't process the audio. Not sure on this one but I suppose it could be true....
Anyway he changed a setting on his amp's OSD and solved the problem - my problem is my amp doesn't have OSD menus and I cant find anything in the instructions...
Onkyo Manual link :
http://www.uk.onkyo.com/downloads/1/4/7/0/3/TX-SR505_Eng.pdf///
Paul
Hi again
Could this be the root of my problems ?
http://www.uk.onkyo.com/faq/index.php?action=artikel&cat=2&id=30&artlang=en&highlight=dual+hdmi
sounds pretty near the mark   :S
Paul
FunkyMonkey's picture
Last seen: 2 days 15 hours ago
Personally, I would get the
Personally, I would get the best full size speakers you can get for your budget.
If not sure, go for ones with good review and looks that fit your taste.
I'm a Tannoy man, so I would obviously recommend those.
Log in to post comments
