No surround sound coming out from tv on internet
7 replies [Last post]
Horgan
Horgan's picture
Hi
I have a panasonic tx-p55vt50b connected to my yamaha amp rx 1067 with a hdmi lead. The tv is a new purchase and I have set up a wireless connection to enable me to enjoy the various internet features the tv offers. No problem in accessing the various apps, but I'm receiving no sound via my amp. If I disable the amp, then I do hear sound via my tv speakers. I'm guessing I need an additional cable!
What I dont understand though is my ps3 is connected to the same amp via hdmi and when I access the internet via the ps3, I hear sound via my amp.
Can anyone provide me with some guidance please.
__________________
simonlewis
simonlewis's picture
Online
RE: No surround sound coming out from tv on internet
You could try selecting viera link on your tv & making sure it outputs sound via home cinema, -see if that works.
__________________
formerly known as slewis ---
simon's system
Horgan
Horgan's picture
Thanks for your response.
Its already set to play via home cinema and does when watching anything other than when I access the internetpuzzled
__________________
professorhat
professorhat's picture
Online
This is presumably trying to use the ARC functionality to send sound from the TV back across the HDMI cable? If so, what kind of HDMI cable do you have - I think this will need to be one that is certified as high speed to allow this to work. Also, the spec of the TV says Input 2 has ARC functionality - is your amp connected into the HDMI socket labelled Input 2 on the TV? If not try this and see if that fixes it.
The reason the PS3 works okay is because all sound is travelling from the PS3 to one of the amp's HDMI input sockets, so all sound will work okay. For the TV, you're trying to send sound back to the amp's HDMI output socket using the ARC function, and this is why things differ.
Horgan
Horgan's picture
Thanks Professorhat. Excellent advice which resolved the problem. Thank you.
However it's created a new problem now. When I turn the tv on, I have to press a switch on the remote to switch to hdmi2 to watch tv. Previously it was assigned to hdmi1 so tv came on automatically . Any ideas how I can teach the tv to switch onto hdmi2. Tv is assigned in set up menumtomswitch onto av as oppose to tv, but other than that I'm struggling
Thanks for any help
__________________
Horgan
Horgan's picture
Edit
Last line should read.        tv is assigned in set up menu to switch on via av as oppose to tv , but other than that I'm struggling
__________________
professorhat
Online
I can't help with this one I'm afraid as I don't know that TV. I'm guessing there's no setting to default to powering on to a certain HDMI input?
If not, my only other suggestion would be looking at one of the Logitech Harmony remotes (or other manufacturer's equivalent) which you could program to actually change the input to the HDMI Input 2 whenever you switched the TV on. You wouldn't need one of the high end ones for this, the basic 300 model (or 300i which has a glossy finish) would be able to do this.
Horgan
Horgan's picture
Thanks again Professorhat/
I was going to look into the Harmony remotes to keep my family happy:)
Incidentally I have discovered the Panasonic hotel mode which allows me to set the tv to switch onto hdmi2 - saves me pressing a button, but again more for the family and ease of use.
Thanks again
__________________
